InvMark by TFI & Cadac, Inventor Performance Hardware Benchmark Tool with Leaderboard
Neil_Cross
Mentor Mentor
Message 1 of 180
Neil_Cross
Dear all - it's a pleasure to hand over to you, InvMark for Autodesk Inventor, a comprehensive hardware benchmarking solution designed entirely by myself, developed & hosted by Cadac Group, offered to the Autodesk community completely free of charge.
You can download InvMark for free from here
InvMark has been under intense continuous development for over 14 months, ensuring we release a fully featured and stable solution representative of the experience and knowledge behind it.  It runs as an addin within Autodesk Inventor, and is currently supported on Inventor 2021 and 2022.
InvMark has over a dozen test scenarios, including large 1000 part assembly pattern and constraint tests, large assembly drawing computation, FEA, Dynamic Simulation, multi style and context sensitive graphics tests, ray tracing and much much more.
InvMark grades your workstation/laptop and generates an InvMark score, along with a single-core and multi-core score based on how it performed on feature sets that leverage the CPU in different ways.  Each individual test is also graded separately allowing for finite comparisons between tests and hardware on a test by test basis.
InvMark has a public leaderboard where you can upload your score and compete against others in the Autodesk community, or visually compare your workstation to see how its performance sits against todays modern hardware.
The leaderboard is feature rich with a full score report card available for each test, along with full system specs and reference data.  Once logged in, you can see your historical uploads as only your highest score makes it to the leaderboard.
My introductory video announcing the release is here:
We have also integrated a unique feature which enthusiasts may find especially fascinating, our hardware sensor logging.  Every InvMark test (unless disabled) will log all available hardware sensors, every second, to a local CSV file.  This file contains CPU clock frequencies per core, temperature, RAM usage, GPU load, VRAM load, fan speeds if available, if your system has a sensor we log the data for you to convert to a graph for evaluation.
I have created an extensive InvMark tutorial here which includes an overview of all tests, an explanation of all features along with a guide for how to use the hardware logging graph.
Thanks for your interest if you intend on trying out InvMark, we'll see you on the leaderboard 😉
Replies (179)
Message 161 of 180
alh-telesis
I see others had this issue, but I did not see a solution.
I've run the Inventor Reset, I've tried the UNLoad the add-in and I've tried uninstalling the Add-in's ... but no love.
Any help would be appreciated .
Message 162 of 180
SBix26
This topic concerns the InvMark add-in for Inventor.  For installation and licensing help for Autodesk products (such as Inventor Nesting), try posting in the Installation & Licensing Forum.
Sam B
Inventor Pro 2025.1.2 | Windows 11 Home 23H2
Message 163 of 180
alh-telesis
Yes ... Yes it does ...
My Installation of InvMark works well ... until the end when it starts to turn on the ADD-IN's again. Then it crashes Inventor with this and another error.
Message 164 of 180
jochen.bardonner
Hi all,
same to my AddIn installation, but with Inventor 2024.
MSI Logfile says something wrong with "ImportCertificate.bat" Command. This works when run interactively.
2024-10-01_16-14-41.jpgAny hints to that?
Is the Plugin working also with Inventor 2024?
Best
/Jochen
Message 165 of 180
alh-telesis
Mine fails after completing the test in IV 2023
Message 166 of 180
Neil_Cross
Hi all - thanks for the reports, the dev is looking into it and I'll provide an update ASAP.  But yes InvMark should work on Inventor 2024 & 2025, it supports all versions going back to 2020.
Cheers
Neil
Message 167 of 180
alh-telesis
FYI - Things I tried without success,
Turning Off Auto Load Add-In's, Inventor CAM and Inventor Nesting.
Uninstalling Inventor CAM and Inventor Nesting.
Reinstalling Inventor CAM and Inventor Nesting.
Turning Off Auto Load Add-In, Factory: Layout/Simulation.
And Thank you for creating this tool. Whether it works for me or not, I appreciate your effort.
Message 168 of 180
Neil_Cross
Hi all - apologies for the delay, AU and various other things have made it difficult for us to sort things out but we've just uploaded a new version to the website, if you can try that out it should resolve most of the issues I've seen here.
Uninstall the version you have now (if you were able to install it) and then give the new one a shot.
Thanks!
Message 169 of 180
alh-telesis
Inventor 2023 from the Factory Design Suite ... works for me.
Thank you.
Message 170 of 180
MarkusGreifeneder3360
Hi, I tried to install the latest Version.
With following result:
I tried to uninstall the "Edge WebView2-Runtime", but in Win10 it's not removable (greyed out), like mentioned in your youtube video.
Also tried a different pc with the same result....
Any idea what could help, to install this tool?
Message 171 of 180
ruben.vaneenoogheYGXKB
Hi Neil, first of all thank you for creating and maintaining this wonderful tool. We already used it in the past and were able to configure new pc's in a good and objective way.
We now tried to install the InvMark again on our current Windows 10 devices that run Inventor 2023, and just like #MarkusGreifeneder3360 we also get this error.
Would there already be a fix for this problem?
"There is a problem with this Windows Installer package. A program run as part of the setup did not finish as excepted. ... "
We don't get the error on Windows 11 devices. So for what we see for the moment, it seems to be a Windows 10 thing.
Kind regards, Ruben
Message 172 of 180
Hi, we also have no problems on win 11 machines. But on win 10.
Message 173 of 180
batuhanozmen98
After the test run, Im getting this error "Please restart Inventor to make sure all addins are loaded again"
Inventor 2021
I do not have pro version so do not have FEA module
windows 11
How can I solve this.
Message 174 of 180
da_matte
Hello, I wanted to use this to test our fleet of (admittedly aging) worksations, but the msi file refuses to install on most of them, stating the following:
"There is a problem with this Windows Installer Package. a program run as part of the setup did not finish as expected. Contact your support personnel or package vendor."
Given I'm the support personnel and am clueless, I'm posting here for any clues. yes it installed without issue on my windows 11 brand new PC. It will not install on the older workstations running windows 10.
Message 175 of 180
da_matte
Upon further inspection, it looks like many others are having the same issue. Forgive me for beating a dead horse, but if there's any tests I can do, please let me know.
Message 176 of 180
MarkBrouwersY48AV
Hi everybody, just to let you know that the 2026 version of Invmark is available for you to download now.
Cheers,
Mark Brouwers
Lead developer at Cadac
Message 177 of 180
Schredhammer
Inventor crashes during the "executing create sweep feature". This happenes in both 2025 and 2026.
Message 178 of 180
SBix26
My very underpowered machine (Ryzen 5 3600, 16 GB RAM, Radeon RX 570) sweated blood but did not crash during the test on Inventor 2026.
Sam B
Inventor Pro 2026 | Windows 11 Home 24H2
Message 179 of 180
Schredhammer
I just ran the Inventor Reset Utility, and InvMark is running all the way through as it should.
Message 180 of 180
dylancNXZ6F
Hello, I'm getting wildly different results on a brand new system with an Ultra 9 285K CPU, without changing anything. I wiped the SSD and installed everything fresh, but it only got worse. On this run for example, the Multi-Core test scored only 2548https://invmark.cadac.com/#/detail/5629
On a previous run, the Multi-Core number was 13115. https://invmark.cadac.com/#/detail/5628
Has anyone seen behavior like this? I'm trying to figure out if it's a real problem with the system or just a glitch in InvMark.
