Inventor Forum
Inventor: Workplane resize/move in assembly behaves differently from part
5 REPLIES 5
pball
611 Views, 5 Replies
I just noticed that I am unable to move a work plane created inside of an assembly. I am only able to resize it symmetrically around the position it was created at. Inside of a part I am able to resize a work plan asymmetrically and move it. This is really annoying and seems really weird.
Has it always been like this? Is this a known limitation?
I'm running 2018.3.3 if that makes any difference.
5 REPLIES 5
Sergio.Bertino
in reply to: pball
Hello @pball
Thanks for your interesting post.
I have to admit that for a moment a struggled a bit to understand what was wrong there, but it can be easily solved following the instructions on the following technical article:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Please let me know if it helps!
Sergio Bertino
MFG Technical Support Specialist
pball
in reply to: Sergio.Bertino
I already figured that out and that is not the root of what I'm trying to explain. Hopefully a video will show the difference I'm trying to explain.
In the part I'm able to move and resize the work plane. In the assembly moving does not work and the work plane is only resizable symmetrically around the center of the plane.
Cadmanto
in reply to: pball
Does this thread help you with your situation?
https://forums.autodesk.com/t5/inventor-forum/resizing-work-planes-in-iam/td-p/7439297
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
karthur1
in reply to: pball
I see the same thing in 2018 as what you are showing.  However, you can move the origin planes in the assembly (make sure the "Auto-resize" is unchecked).  If your assembly user workplane is based off of the origin workplane and the origin workplane moves, then so will the plane built from it when it is resized.
I can just never get the move icon when trying to move the user defined workplane.
I see the same thing in 2019.2
Kirk
Here is a screencast.
Screencast will be displayed here after you click Post.
14db06e9-5a16-4613-bddd-fd5730283e54
pball
in reply to: karthur1
@Cadmanto
Seems like the consensus from that thread is it is possible to resize assembly work planes with the understanding the center is locked and it cannot be moved as it's centered on the origin work plane. Which follows what I've experienced.
@karthur1
You're seeing what Cadmanto's linked thread says and what I've seen.
To sum things up assembly work planes can be resized but the position is locked to what it was created using. It seems a user from the linked thread did make an Idea post requesting assembly work places to behave like part ones do, so hopefully that could be implemented some day.
https://forums.autodesk.com/t5/inventor-ideas/resizing-work-planes-to-any-size-in-iam-same-as-in-ipt...
Technology Administrators
