Inventor Forum
Inventor Sheet Metal mm Template Differ From Punch With Inch Units
8 REPLIES 8
Message 1 of 9
747 Views, 8 Replies
Hello,greetings of the day.I made my template of sheet metal in mm but when i'm using punch tool it's showing only in inches that too some predefined values.How can I over come this?
kelly.young has edited your subject line for clarity: Sheet metal
8 REPLIES 8
Message 2 of 9
MSD_takaseh
Hello varun94prashanth,
Most of punch tools are created in inches as unit. I think it's not possible to change unit from inch to any when inserting.
You need to create a new ide in mm as unit or edit existing ides.
Hitoshi Takase
Message 3 of 9
in reply to: MSD_takaseh
What do you mean by IDE?
Message 4 of 9
MSD_takaseh
IDE means iFeature. The punch tool iFeatures are in C:\Users\Public\Documents\Autodesk\Inventor 201X\Catalog\Punches
Hitoshi Takase
Message 5 of 9
S_May
@Anonymous,
show us the tool (please upload the ide)
Message 6 of 9
in reply to: S_May
when choose punch tool the dialogue box opens like the attachment
kelly.young has embedded your image for clarity.
Message 7 of 9
johnsonshiue
Hi! I think you can open the .ide file in Inventor and change the default parameter values. Depending on the geometric condition, if you change the parameter value too drastically, it can lead to modeling failures. Try it out and see if the desirable mm values work for you.
Many thanks!
Software Test Engineer
Message 8 of 9
in reply to: johnsonshiue
Thank you for your reply.I didn't get your point.kindly send any Tutorial files
Message 9 of 9
johnsonshiue
Hi! The process is pretty straight forward. Simply open the ide file in Inventor. There is a button called "Edit iFeature." You can change the default parameter values in the extracted features. Could you try it out and see if it works?
Many thanks!
