Hi, i have a weird thing, i have installed Inventor and Vault on 3 machines here and one of the users get a weird save dialog window when trying to save a part, assembly, ect.
He only get the weird window when he's logged into vault thru inventor.
His save window: Save window.jpg,
My save window: Save window2.jpg
I'm sure there's a simple checkbox to click and it's fixed but i can't find it.
Solved by clutsa. Go to Solution.
Solved by RoarH. Go to Solution.
Solved by andrewiv. Go to Solution.
The window he's seeing has to do with Vault Data Standard. Check out this thread for a solution. https://forums.autodesk.com/t5/inventor-forum/inventor-2020-save-new-file-am-i-missing-something/m-p...
Andrew In’t Veld
Designer
Enable Data Standard for Inventor or AutoCAD
Once the file is opened, the Data Standard tab becomes visible on the icon ribbon.
As an FYI, we just did an update from 2020 to 2022 and the single user that ended up with Data Standard enabled didn't have those nice big buttons to enable/disable the feature.
We did get it shut off under the Tools->Add-Ins->Vault Data Standard. Uncheck Loaded/Unloaded and Load Automatically.
Sorry for reviving an old thread but just in case anyone else has this issue, we had to do it different then the posts above.
