I use Inventor 2013 on a machine that is running Windows 10 Pro version 1903, I've already installed all service packs and it's opening normally, but when I'm going to use Place from Content Center it opens the library and then when I click on the item I want to use, the inventor closes itself without any error. Does anyone know how to solve this problem?
note: the library opens normally, but when I click to generate the component the inventor closes.
Solved by DarrenP. Go to Solution.
2013 is not supported on windows 10 even if a bug was caused by 1903 there is a small chance that this will be fixed for 2013
there is a on going thread for issues with 2018 & windows 10 build 1903
the fix was to roll back to a previous build until Autodesk releases a fix but this is for 2018 & not 2013
DarrenP
Hi Tetsu,
Darren is right. Inventor 2013 does not support Windows 10. You will run into more problems down the road. If you encounter any other systematic problems, you may not be able to resolve them. Please upgrade to later releases (2017 or later).
Many thanks!
