Hello everyone,
I have been doing a project for work, a little boiler room.
We use mapress stainless steel pipework. My question is: when I need to set up pipe styles I cannot find the right one that works for me.
Any advise? And how do I chose the correct types of fitting in relation to the pipework type?
Many thanks
Solved by CGBenner. Go to Solution.
Hello and welcome!
In the Content Center there are hundreds, or maybe even thousands of pipes and fittings available,... but it may not include the ones you need for your design. I saw this all of the time when I was doing pipe design. Very often you may need to create your own pipe and fitting libraries by modeling iParts and then Authoring and Publishing them to the Content Center for use with Tube & Pipe. Often, you may be able to download fittings from sites on the internet, or from the manufacturer's website. These too, would then need to be authored and published. Does this help?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi, yes thank you.
What about pumps, valves, ball lever valves and the other equipment? Do you know where I can download them? That would be very usefull.
Thank you
Simone
@roversimone.uk wrote:
Hi, yes thank you.
Thank you
Simone
It really depends on who the manufaturer is. There are quite a few who do have CAD models available, but just as many who do not. Most will at least have dimensional catalog drawings... they're not great but you can use them to create amodel on your own that is at least dimensionally correct... even if it's not pretty. I would use Google to search for the specific manufacturer whose products you will be using.
Do you know how to do the authoring and publishing?
Chris Benner
What do you mean for authoring and publishing? yes I think I can, but maybe you mean something else?
Authoring and publishing are the steps that need to be done to prepare your fittings and equipment for use with tube & pipe. This link is to a class I did at Autodesk University 2019 that explained a lot of the different methods. When you get to that point, maybe this will help (if you need it).
Chris Benner
Hi, I have been watching the video, the really first part is about creating a library in order to have access for everything I need.
Basically I have my assembly already done (please see attached) and all I need to do is just creating the pipework. What should I do from now on? Do I need that step? If so, I an not able to do it because my Inventor shows different things. I am not able to follow your instructions.
I really need all these fittings and so on, but I cannot do anything you are showing.
let me know
What you have created is an equipment layout. Now you need to enter the Tube & Pipe environment and begin to create Routes and Runs. Learning Tube & Pipe is going to take some practice, there is a lot to know. I am going to share some more resources for you to help you getting started.
First, here is a list of some YouTube videos about using tube & pipe. Maybe seeing some deomnstrations will help you out.
And this link is to a post in these forums from a few years ago, with a lot of good resource links for getting started.
Chris Benner
