Inventor Tube & Pipe basic tutorial
weslie_howard
weslie_howard
I am looking for a good basic tutorial on the Tube & Pipe environment for Inventor. I am hoping I can get pointed in the right direction by folks here in the forum.
I have been using Inventor Pro for a few years now, but I am just not needing to use the Tube & Pipe feature. So if any of you have a recommendation I am all ears.
Keith Howard
Designer
Northrop Grumman
Cadmanto
Keith,
Chris Benner is the true expert when it comes to this topic.  Take a look at the attachment written by Chris with his contact info.
Hope it helps you.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
kelly.young
Autodesk Support
Autodesk Support
Hello @weslie_howard here are a few good threads with links that should be helpful:
Learning Tube & Pipe From Beginning, Looking For Tutorial
Tube and Pipe tutorial files
Inventor Tube and Pipe Training & Tutorials
install Tube and pipe tutorial 2017
Help with Tube and Pipe
Please select the Accept as Solution button if a post solves your issue or answers your question.
weslie_howard
Thank you all for the suggestions and links!
Keith
