I am looking for a good basic tutorial on the Tube & Pipe environment for Inventor. I am hoping I can get pointed in the right direction by folks here in the forum.
I have been using Inventor Pro for a few years now, but I am just not needing to use the Tube & Pipe feature. So if any of you have a recommendation I am all ears.
Keith Howard
Designer
Northrop Grumman
Solved by kelly.young. Go to Solution.
Solved by Cadmanto. Go to Solution.
Keith,
Chris Benner is the true expert when it comes to this topic. Take a look at the attachment written by Chris with his contact info.
Hope it helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hello @weslie_howard here are a few good threads with links that should be helpful:
Learning Tube & Pipe From Beginning, Looking For Tutorial
Inventor Tube and Pipe Training & Tutorials
install Tube and pipe tutorial 2017
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
