Inventor Forum
Inventor not importing Company iProperty correctly
2 REPLIES 2
Brandon_Mooney
115 Views, 2 Replies
Good afternoon,
When exporting an Inventor assembly as a .stp file, the "Company" iProperty correctly does as described here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Inventor-Which-iPr...
Issue:
When importing a .stp file, Inventor does not treat the 4th parameter of the FILE_NAME() line as the "Company" iProperty, and instead imports it as a custom property titled "Organization".
Desired Behaviour:
What goes out should be what comes in, no?
I'm looking at how to automatically populate the "Company" iProperty upon import of a .stp file. Currently, the desired "Company" information is present in the 4th parameter of the FILE_NAME().
ex.: FILE_NAME('name','time','author',COMPANY_PARAMETER_AS_EXPORTED_BY_INVENTOR,'','','')
Does anyone have a solution kicking around to automate this by chance?
-Brandon
2 REPLIES 2
Hi Brandon,
On importing the STEP file, the Import dialog has a property mapping button. Click it to map the properties desirably. Have you tried that?
Many thanks!
Software Test Engineer
Thank you Johnson!
For those who find this post wondering the same thing:
The "Property Mapping" button lets you map any custom properties that get imported to a standard property.
Because Inventor is importing the 4th parameter of FILE_NAME() as a custom property titled "Organization", mapping "Company" to "Organization" for STEP files is a modal solution (Property Mapping selections are saved).
Technology Administrators
