Good afternoon,
When exporting an Inventor assembly as a .stp file, the "Company" iProperty correctly does as described here:
Issue:
When importing a .stp file, Inventor does not treat the 4th parameter of the FILE_NAME() line as the "Company" iProperty, and instead imports it as a custom property titled "Organization".
Desired Behaviour:
What goes out should be what comes in, no?
I'm looking at how to automatically populate the "Company" iProperty upon import of a .stp file. Currently, the desired "Company" information is present in the 4th parameter of the FILE_NAME().
ex.: FILE_NAME('name','time','author',COMPANY_PARAMETER_AS_EXPORTED_BY_INVENTOR,'','','')
Does anyone have a solution kicking around to automate this by chance?
-Brandon
Solved by Brandon_Mooney. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi Brandon,
On importing the STEP file, the Import dialog has a property mapping button. Click it to map the properties desirably. Have you tried that?
Many thanks!
Thank you Johnson!
For those who find this post wondering the same thing:
The "Property Mapping" button lets you map any custom properties that get imported to a standard property.
Because Inventor is importing the 4th parameter of FILE_NAME() as a custom property titled "Organization", mapping "Company" to "Organization" for STEP files is a modal solution (Property Mapping selections are saved).
