Inventor Forum
Inventor Nesting wont install
7 REPLIES 7
Message 1 of 8
Vitornis
565 Views, 7 Replies
Capture.PNGI get to this point everytime and it does not continue. I have let it set here all weekend with no progress.
7 REPLIES 7
Message 2 of 8
LukasZygmunt
in reply to: Vitornis
Hi @Vitornis,
It seems something goes wrong with the Internet connection.  Maybe antivirus blocking download?
I recommend you to go to Autodesk Account > Manage products and downloads > All Products & Services> Select Inventor Nesting to download > Select Browser Download.
Cheers,
Lukasz Zygmunt
Technical Support Specialist
Message 3 of 8
Vitornis
in reply to: LukasZygmunt
Already did that and same problem.
Message 4 of 8
LukasZygmunt
Are you in Windows admin account?
Did you turn off antivirus?
The screen which you attached shows that there is an issue with a download of the file. Now you should have another message.
Cheers,
Lukasz Zygmunt
Message 5 of 8
Vitornis
Message 6 of 8
Vitornis
I redownload the Browser Download and it continues with the same problem. I disabled my antivirus and this is a admin account.
Message 7 of 8
LukasZygmunt
Hi @Vitornis,
After the installation in the temp  folder (%temp%) open file :
"Autodesk Nesting Utility 2019 Install.log" (should be in a folder with number name "1")
You can open this file and check where Installation is falling. If you do not find anything, you can send me a private message with this file.
Before next installation, you can check if Windows has this installation files (I mean Control Pannels> Uninstall programs).
And check registry using Fix-it:
https://knowledge.autodesk.com/customer-service/download-install/remove-products/using-microsoft-fix...
Cheers,
Lukasz Zygmunt
Message 8 of 8
Vitornis
I finally got it to install. I restarted the computer, shut down anything antivirus or firewall in the windows settings and used the last browser download and after all that voodoo it finally installed!
