Inventor model tree / browser missing
Message 1 of 15
I'm using Inventor 2018 with a student license. Sometime today my model tree / browser has gone missing, no idea why.
I googled the problem but all I found was:
[View tab... User interface drop down in the windows pane.. Check "model"].
The problem is, as you can see in the screenshots, it's checked but it's just not there. Any ideas?
Thanks!
Replies (14)
Message 2 of 15
MechMachineMan
Try finding and downloading the inventor reset utility.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 15
mdavis22569
did it get moved off the screen or hidden behind it ... the Browser can move around now. Much easier than previous versions.
Mike Davis
Message 4 of 15
mcgyvr
Do this.. Its located in the Autodesk Inventor 2018 folder in your Windows Start menu (or whatever its called now in Win10)
"Inventor reset utility"..
Close Inventor then run it..
Message 5 of 15
Yes, the reset utility solved the problem. Thank you!
Message 6 of 15
JamesCipolloni7683
I can't believe the fix for this clears all your personal setting, this fix is no were to be found on the internet except here, thanks the info.
Without the browser the software is useless
Jim Cip
Message 7 of 15
SBix26
Save settings before using the Reset... too late now, of course.
Sam B
Inventor Professional 2018.1.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Message 8 of 15
go to VIEW tab
click the pull down for USER INTERFACE
make sure MODEL is checked
Message 9 of 15
TheCADWhisperer
@Anonymous
Do you mean something like the OP's Prob 2.png image?
Message 10 of 15
Thanks!!
Message 11 of 15
Thank you!!!
I have searched for this all day, but I could never get a direct answer until now. Once again, thank you so much for all of your help today. I really appreciate it.
Best Regaurds,
Zion Moss, PhD.- Biomedical Engeneering- Biological Sciences
National Research Executive
Washington D.C. Intstitute of Technologies and Advancements
Senior Researcher of National Pentagon of Security
Message 12 of 15
stephanie.canora
Hi everyone! In addition to the solutions mentioned earlier (reset utility and view tab > click user interface > check 'model'), the Inventor team made an update in Inventor 2020 to improve this experience. If the model tree gets closed, you can click the plus sign highlighted in the picture and select 'Model Browser' from the dropdown.
Stephanie Canora | Product Manager, Product Design & Manufacturing Collection
Message 13 of 15
k14348
    Go to View tab then user interface then dropdown then check browser box.
-Karth
Message 14 of 15
marcusjerne
Community Visitor
Community Visitor
Thnaks!
Message 15 of 15
david_farr7Y3TM
Community Visitor
Community Visitor
Thank you.
