FDS 2018 Inventor (Sketch constraint deletion problem!)
3DAli
3DAli
johnsonshiue
Hi Ali,
I cannot seem to reproduce the behavior. Are you using 3D Connexion device?
Many thanks!
Software Test Engineer
Scott_Parker
Can you post the file?
Scott
Scott Parker
Principal Software Engineer
3DAli
yes I do use 3D connexion space navigator .
3DAli
Hi Scott,
I will send you the file next time I run into it.
Thank you for your help
johnsonshiue
Hi Ali,
I suspect some of the issues you are encountering might be related to 3D Connexion. Based on the following thread, a user contacted the vendor and found out Inventor 2018 is not yet fully supported. I cannot say it for sure that all your issues are related to this but the fact that we cannot reproduce it in house seems to indicate the case. I will work with project team to understand the issue better and also we will try to contact 3D Connexion to confirm it.
https://forums.autodesk.com/t5/inventor-forum/help-with-inventor-2018-and-my-spacemouse-enterprise/m...
Many thanks!
3DAli
Thank you Johnson,
appreciate it,
Ali
