Let me give you history to the problem. I was getting wrong segment outside diameter so i figured my individual wire has wrong outside diameter which was causing that issue so to resolve in Inventor Harness library if I update outside diameter of wire in library, 3D model wire assembly is not getting updated with new outside diameter of wire. I tried library synchronization as well but inventor got stuck. if i say yes to sync No updates even after i waited for hours. I am not sure if my model is too big or inventor library doesn't support later on updates ? Please help me and suggest if anyone has solution to this problem.
