Inventor Forum
can not combine bodies
6 REPLIES 6
5272 Views, 6 Replies
i am having some problems with combining more bodies (10 in my case). I need to create one body out of them since i have to open this file in moldflow and i noticed that multi-bodies are not supported in moldflow. If the model does contain multi-bodies, only the first body is displayed. Then i want to create one body out of 10 and save this new body as a part. I am trying to use "combine" to combine the bodies but it gives me this erroe:
Create combine feature failed
finale.ipt errors occurred during update
Combine8: could not build this combine
The attempted operation did not merge the risults of the face-face intersections successfully. Try with different inputs
I am new to autodesk inventor and i really don't know how to solve this problem. Thank you in advance
Tags (1)
6 REPLIES 6
hosford
Using Combine I had no issue in making a single body.
I added one at a time, then I tried it by adding all bodies that touched the first, then the remaining bodies, both ways worked, gave me "Solid Bodies (1)"
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
kelly.young
Greetings @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
As you can see from the attached screencast it depends on which body you choose first.
I tried to get it to show your error and the different selection order so you can see what the results were. Hope this helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
SBix26
I think the easiest way to do this is to start a new part and use the Derive tool to bring in your multibody part, choosing the option "Single solid body merging out seams between planar faces".
I think this will do what you're asking pretty easily, and is, of course, associative back to the original part.
Sam B
Inventor Professional 2018.1.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
kelly.young
in reply to: SBix26
Thanks @SBix26 that is way easier, I was just trying to do it @Anonymous way with the combine command, didn't even think about exploring it like that!
Coras_Alin
in reply to: hosford
It works if they are done in Inventor, else just problems
Coras_Alin
