Can I design a rocket house in inventor?
thanks,
kas
kelly.young has edited your subject line for clarity: Rocket design
Solved by NachitoMax. Go to Solution.
Hi there,
It's possible to build this model, it's not complicated. The matter is just the way to do it to save time.
In my opinion, the quickest way is to use surface method. You build the side surfaces of rocket play house using loft.
Then slice it with array of horizontal planes (Rectangular array) and vertical planes (Circular array). Then you thicken individual small planes and you will get your result.
Cheers
Marshall
Hi! If this is a commercial project, I would suggest you contact the source of the model. You need to obtain the consent to replicate the model for commercial purpose.
Many thanks!
#frustrated
i had a free evening so ventured into modeling this . took me about 25 mins to get the structure, panels, shape, inside timber and port holes. **** thing crashed as i clicked save.....
The best approach it to model the 1/8th section and then use a circular pattern to send it round.
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Hi Nacho,
Did you send in the crash report? Are you able to reproduce the crash?
Many thanks!
Hi johnsonsiue
No i didnt send the crash report. To be fair, my mschine had been on most of the day (some 15 hrs) and inventor was open for most of that time doing nothing. I dont usually have any issues
Nacho
Nacho
hello @Anonymous,
if you work a lot with wood, please do that with this software (in inventor):
woodworkforinventor. & youtube
I did it again. took about 40 mins all in all
Cheers
Nacho
FYI
WW4I is far too expensive and buggy. also, it only benefits if everyone you work with has it and at over a grand a pop, you'd be better off with other tools on the app store.
Nacho
@NachitoMax, impressive work. Any chance you could attach you files? Would love to see your modeling strategy.
Sure
its only a rough model, nothing special. Ordinarily i wouldnt circular pattern in the ipt, i would leave that for an assembly instead
Nacho
Nacho
