Inventor Error Message Unable To Run Application Manager Service Not Available
I get the following message when I start inventor 2016.
Unable to run application manger,application service is not available.
What should be done
kelly.young has edited your subject line for clarity: Error message
Accepted solutions (3)
Mark.Lancaster
@Anonymous
So you have the old application manager installed or do you have the new desktop app installed?  This is the interface that used for updating your Autodesk product.
Is Inventor actually working or not?  If it is, don't worry about the message or uninstall the app (but not Inventor).
Mark Lancaster
Cadmanto
This link seems to speak to this issue around the time of your version.
https://forums.autodesk.com/t5/inventor-forum/application-manager-service-not-available/td-p/5726106
I am guessing that this didn't just start happening.  You might want to consider as suggested in this link about upgrading.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! You don't need Autodesk Application Manager to run Inventor. Try this. Close all apps. Go to Control Panel -> Programs and Features -> Autodesk Application Manager -> right-click -> Uninstall/Change -> Uninstall. After that, does Inventor work now?
Many thanks!
Software Test Engineer
I have uninstalled as per your suggestion. I have restarted the computer, error message did not appear. I have started inventor 2016, I will work on it and come back to you if it has some problems in working
I had unstalled as per the suggestion and had no problem with working of inventor 2016
