I downloaded and installed the Autodesk Inventor 2022 educational version. But when I opened it, it is asking for a serial number. I can't find the serial number in my Autodesk account. How do I complete the installation?
Go to http://manage.autdesk.com
and click on All Products....
What do you see here on the Activation tab?
Hi @Anonymous,
Serial Numbers (at least for Students) have been replaced for just sign in based activation, hence why you see no serial number.
Since you don't see a sign in option follow this article to ensure you can connect to Autodesk to activate your license: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/No-Let-s-Get-Started-Window-or-System-Error-Repair.html
Thanks, I turned off the firewall now the Inventor is opening, but as soon as it opens it turns off and shows this message.
Well, now we have multiple problems.
Did Inventor run OK in Trial mode on this machine?
Back to the Student License...
What does it show as the login in upper right corner of http://manage.autodesk.com
Are you using the correct Sign In for your Student account?
Hi! Please make sure all critical Windows updates are installed and graphics driver is up-to-date (yours is 2015). Also check the minimum system requirement.
Many thanks!
