Inventor Forum
Inventor educatioal version installation
6 REPLIES 6
569 Views, 6 Replies
I downloaded and installed the Autodesk Inventor 2022 educational version. But when I opened it, it is asking for a serial number. I can't find the serial number in my Autodesk account. How do I complete the installation?
Labels (3)
6 REPLIES 6
JDMather
Go to http://manage.autdesk.com
and click on All Products....
What do you see here on the Activation tab?
Thank you for your reply. I see like this
leowarren34
Hi @Anonymous,
Serial Numbers (at least for Students) have been replaced for just sign in based activation, hence why you see no serial number.
Since you don't see a sign in option follow this article to ensure you can connect to Autodesk to activate your license: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/No-Let-s-Get-Started-Window-or-System-Error-Repair.html
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
in reply to: leowarren34
Thanks, I turned off the firewall now the Inventor is opening, but as soon as it opens it turns off and shows this message.
JDMather
Well, now we have multiple problems.
Did Inventor run OK in Trial mode on this machine?
Back to the Student License...
What does it show as the login in upper right corner of http://manage.autodesk.com
Are you using the correct Sign In for your Student account?
johnsonshiue
Hi! Please make sure all critical Windows updates are installed and graphics driver is up-to-date (yours is 2015). Also check the minimum system requirement.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Syste...
Many thanks!
Software Test Engineer
