Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Inventor doesn't load object viewer after Windows reinstall
I own a student license for Inventor and have recently reinstalled Windows on my computer. Back then, Inventor ran beautifully. Now, neither the Object Viewer Window nor the Startup windows show up. A screenshot is attatched.
This issue persists with both Inventor 2020 and Inventor 2021, also after repair and reinstall.
Any Ideas on how to fix it? A Google search doesn't return anything related.
johnsonshiue
Hi! What is Object Viewer? Is it MyHome? Go to Get Started -> Home. Another option is to use Inventor Reset Utility (All Programs -> Autodesk -> Inventor 20xx -> Tools) to reset all settings back to install default.
Many thanks!
Software Test Engineer
Hey, thanks for the answer.
With object viewer I mean the big central window with the 3D view of the
object. In fact, the main window on startup is also affected.
This is a fresh install of Inventor and all settings are as installed.
johnsonshiue
Hi! I think you are talking about MyHome. Go to Tools -> App Options -> General -> Show MyHome on startup.
Many thanks!
Hey,
No, that was enabled. Re-enabling it showed no difference whatsoever.
Anything else it could be?
you just provide a screenshot with no details
provide a lot more details of what your expecting to see vs. what your seeing in your install
based off everything i am still not seeing what the issue is
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
