Inventor Create New Hole Thread
FatmeIsmail
Message 1 of 11
FatmeIsmail
Hello.
Is there any possibility to be add a new thread in Inventor? If this is possible, how can I add a new thread?
Thank you very much!
kelly.young has edited your subject line for clarity: New thread
Replies (10)
Message 2 of 11
Xun.Zhang
Of course you can. Please create a cylindrical hole or cylindrical draft, then, invoke thread command to create a thread on the surface.
Refer more from below link, hope it helps!
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-C0848D58-12CB-4605-8165-0836232927F0
Xun
Message 3 of 11
-niels-
Or if you mean to add new thread types to the list, the link Xun gave also refers to the Thread.xls setup.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-ABB15CD3-60F0-43B9-9B1A-3F9898245B5E
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 4 of 11
FatmeIsmail
Yes, I mean that. I added the new thread in the Thread.xls setup, but when I want the added the new thread in the 3D model, the new thread has not update. My be I should make some updates, I don't know. Please help me, what should I do? 😞
Message 5 of 11
Mark.Lancaster
@FatmeIsmail
Have you restarted Inventor after making changes to the thread table file?
Mark Lancaster
Message 6 of 11
FatmeIsmail
Yes, several time.
Message 7 of 11
Mark.Lancaster
@FatmeIsmail
Not sure why you accepted my reply as a solution if it didn't work..
Anyhow, is this a new type of thread or adding to existing information?
Mark Lancaster
Message 8 of 11
FatmeIsmail
Sorry for that. Inadvertently I pushed "Accept as solution".
Message 9 of 11
mcgyvr
@FatmeIsmail Please post your thread.xls file and indicate which thread (state which sheet and the thread specifics) you have added so we can ensure its formatted correctly..
Message 10 of 11
FatmeIsmail
I added thread M44x1.5-6g (marked in yellow) in sheet ISO Metric profile.
Message 11 of 11
mcgyvr
Works just fine for me..
I'm going to have to assume that you may have multiple copies of the thread.xls folder in different locations on your computer and you just edited the wrong one..
Please check the following locations to see which is which..
tools..application options...file tab.. look at the folder location for the "Design Data (Styles, etc.)" section.
Also look in your project file under the "Folder Options" subfolder and look at the "Design Data (Styles, etc.. =)" location there..
