Inventor crashes explorer when showing thumbnails
amarcoc
Message 1 of 20
amarcoc
Hi.
Ocasionally, when explorer is showing inventor thumbnails, it just crashes.
I catched this error from Windows 10 log:
Nome da aplicação com falha: explorer.exe, versão: 10.0.15063.674, carimbo de data/hora: 0xd8364343
Nome do módulo com falha: ThView.dll, versão: 22.20.22700.0, carimbo de data/hora: 0x59efbe8e
Código de exceção: 0xc0000005
Desvio de falha: 0x0000000000006bf8
ID do processo com falha: 0x2f68
Hora de início da aplicação com falha: 0x01d35715c53d7c70
Caminho da aplicação com falha: C:\WINDOWS\explorer.exe
Caminho do módulo com falha: C:\Program Files\Autodesk\Inventor 2018\Bin\ThView.dll
ID do Relatório: abdcee9b-f203-4127-a923-ce4d8ae90d13
Nome completo do pacote com falha:
ID da aplicação relativa ao pacote com falha:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2017-11-06T15:52:00.390148900Z" />
  <EventRecordID>610674</EventRecordID>
  <Channel>Application</Channel>
  <Computer>PC01</Computer>
  <Security />
  </System>
- <EventData>
  <Data>explorer.exe</Data>
  <Data>10.0.15063.674</Data>
  <Data>d8364343</Data>
  <Data>ThView.dll</Data>
  <Data>22.20.22700.0</Data>
  <Data>59efbe8e</Data>
  <Data>c0000005</Data>
  <Data>0000000000006bf8</Data>
  <Data>2f68</Data>
  <Data>01d35715c53d7c70</Data>
  <Data>C:\WINDOWS\explorer.exe</Data>
  <Data>C:\Program Files\Autodesk\Inventor 2018\Bin\ThView.dll</Data>
  <Data>abdcee9b-f203-4127-a923-ce4d8ae90d13</Data>
  <Data />
  <Data />
  </EventData>
  </Event>
How can this be solved?
Thanks in advanced!
Replies (19)
Message 2 of 20
Yijiang.Cai
Really appreciate you to post this issue to us! I have seen that you use Inventor 2018. Have you installed the latest Update package? Could you have more details about the workflow which cause to crash?
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: [email protected]
Message 3 of 20
amarcoc
I am using version 2018.1.2
I used version 2017.4.2 and the error was the same.
I am in a Windows 10 Pro machine. AMD Rayzen 5 processor, 32 GB RAM.
What kind of aditional information do you need?
Message 4 of 20
Yijiang.Cai
Could you have more details about the workflow which causes to crash? If possible, could you submit the error report to us and provide the email address to us? So that we could dig into the details.
River Cai
Autodesk, Inc.
Message 5 of 20
amarcoc
Hi. There is no error report generated by Inventor. The error is from
windows explorer. Inventor itself done even need to be opened.
What do you mean with the workflow?
Message 6 of 20
I think I have the same problem...
When working with Inventor 2018 I leave some Explorer folders open, usually the folder with the parts of the library and the folders I am currently working on,
With [Alt+Tab] I change the windows and choose in the Explorer the files that I will edit in Inventor.
After some time, sometimes hours, sometimes minutes, Explorer fails to show the part image and only shows the Inventor icon.
The Inventor 2018 continues to work fine, including the "open file", but no other program can open. When you try, a message appears stating "The file name is too large".
I have already reformatted my SSD and installed everything, two or three times.
I"ve already started all a new SSD
I"ve already started all a new computer and with a lot of patience and monitoring We were careful to copy the drawing files, without virus or any file that could interfere and only install Windows 10, office 365 and inventor 2018.
Even so, the bug happens again after a few hours...
This problem appeared em May 2017, as I could not solve it I went back to inventor 2015 and had more problem.
Now in January 2018 I tried again to install inventor 2018 and again the same bug appeared!
Message 7 of 20
johnsonshiue
Hi! The behavior sounds system related. Could you try cleaning up %temp% and see if it works better?
Many thanks!
Software Test Engineer
Message 8 of 20
Hello
my customer has the same problem
Today i re-intall  and formatted Hp z440 workstation. Only install Inventor with al service packs as same for windows 7 but nothing change
After 2 or 3 hours Explorer freeze and so Windows.
Last month I try with windows 10  but same result . With 2016 no problems.
I havent any solution to resolve...
Mauro
Message 9 of 20
johnsonshiue
Hi! I am not aware of a similar issue on Inventor. It sounds like some shared components are missing from the system. Is it on Windows 10 or Windows 7? Could you try the following?
Go to command prompt and type in "C:\Program Files\Autodesk\Inventor 2018\Bin\Inventor.exe /install" to register Inventor.
Many thanks!
Message 10 of 20
Same error with win7 and Windows 10.
Few people use preview thumbnail on Windows.
Some components installed with 2017 or 2018 version cause issue . I found on Autodesk forum another cause with no resolution. Only suggest nota use thumbnail. I try with new installation with Autodesk and Microso latest service packs
Message 11 of 20
michael_marx
Hi Johnson,
i´ve the same issue on two machines with win 10 and Inventor 2018.3.
tried to delete temp and done the cmd registration. after that it works correct for a while but after some time the issue is there again.
Michael
Message 12 of 20
amarcoc
I never got this solved, and Support wasn't good.
Problem remains since I installed Windows 10.
Message 13 of 20
Yuming.Zeng
Hi, Macro,
I assume you're able to easily reproduce the problem, and am not sure if you can please record a video for the crash? And it would also be much helpful if a dump file can be created for the Windows Explorer when it crashes with the Windows Task Manager.
Yuming Zeng
Autodesk, Inc.
Message 14 of 20
amarcoc
Hi.
How can I record screen?
How can I generate dump file with task manager?
Message 15 of 20
Yuming.Zeng
You can use whatever tool to record the video to show the crash steps/workflows, like a mobile if that works for you.
To generate the dump file, you can firstly start Windows Task Manager by right click on the Windows Task Bar, and then select the Task Manager. Then when Windows Explorer crashes, and if there is any message box/dialog box still running on the screen, don't close it, and switch to the Task Manager, and if you can find the Explorer in the Task Manager, then right click on it, and select the Create dump file. Once the file is created, Windows should prompt you where this file is saved on your disk.
Yuming Zeng
Message 16 of 20
It's impossible create log because everything you touch Explorer return same error … Task manager too
Yuming Zeng
sk manager too
Message 17 of 20
amarcoc
Hi.
But explorer just shutdowns. A video record would be same behaviour as clicking the close (X) button.
Also, since explorer just shuts down, there is no window to create a dump. 😞
Any more ideas?
Message 18 of 20
Yuming.Zeng
Does that mean, the Windows Explorer disappears from the screen immediately?
Do you still remember if you viewed the files in Details, List, Small Icons, Medium Icons, Large Icons, Extra Large Icons, or other mode that caused the crash? Would the Explorer.exe crash if you view a folder that doesn't contain any Inventor files (*.ipt, *.iam, *.idw, *.dwg)?
Yuming Zeng
Autodesk, Inc.
Message 19 of 20
amarcoc
Yes. That's what I mean.
It only happens when showing thumbnails (medium / large icons)
Explorer never crashes in folders without inventor files (even if preview is
activated on other file types)
Message 20 of 20
Yijiang.Cai
@amarcoc we are working with customer to investigate the issue, and provided one fix to customer for validation in customer environment. If the issue is really fixed in customer environment, we will continue the follow up actions.
River Cai
Autodesk, Inc.
