Inventor Forum
Inventor crashes after 3Dconnexion update v10-7-2
4 REPLIES 4
tobias
382 Views, 4 Replies
Inventor crashes after I installed the new update from 3Dconnexion. I tried reinstall but didn'work.
I also searched to do a repair installation on Inventor but cannot find it anymore.
Anybody having the same issue ?
Tobias
Tobias
The Netherlands
Inventor Pro 2025, Vault Pro 2025, AutoCad Electrical 2025.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Tags (1)
4 REPLIES 4
bradeneuropeArthur
in reply to: tobias
unzip the .exe file and run that exe in the zip file!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
https://forum.3dconnexion.com/viewtopic.php?t=38494
Arthur Knoors
tobias
in reply to: bradeneuropeArthur
Hi @bradeneuropeArthur, thanks for the reply.
The problem is not with installing 3Dconnexion. After installing the newest version of 3Dconnexion, Inventor will not start anymore. Just before the homescreen comes up, Inventor crashes.
Reinstalling the previous version of 3Dconnexion will resolve this issue.
Tobias
The Netherlands
in reply to: tobias
you just proved this isn't an Inventor issue its a problem with the latest version of the 3dconnexion software
Technology Administrators
