Message 1 of 29
Inventor can't open two versions of the same file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Since upgrading to Inventor 2024, we frequently get error messages like these:
Part XYZ.ipt [or Assembly ABC.iam] v23 is opened in Inventor and loaded into cache. The file located at [file path]\Part XYZ.ipt is a different file version. Inventor can't open two versions of the same file (where path and file name are the same) in the same session. Save your work, and then close and reopen the documents using the file to clear the cache.
Can anyone help identify the reason for these messages? Currently we are using Inventor 2024.1.1 along with Vault Basic 2024.1 Update, and our workflow is the same as it was prior to the upgrade.
