Inventor can't open two versions of the same file
iamerm
Message 1 of 29
iamerm
Since upgrading to Inventor 2024, we frequently get error messages like these:
Part XYZ.ipt [or Assembly ABC.iam] v23 is opened in Inventor and loaded into cache.  The file located at [file path]\Part XYZ.ipt is a different file version.  Inventor can't open two versions of the same file (where path and file name are the same) in the same session.  Save your work, and then close and reopen the documents using the file to clear the cache.
Can anyone help identify the reason for these messages?  Currently we are using Inventor 2024.1.1 along with Vault Basic 2024.1 Update, and our workflow is the same as it was prior to the upgrade.
Replies (28)
Message 21 of 29
DperronU8V4S
i do loose my mind on this
it is make me loose soo much time of production as they only drafter at my work supplying drawing more then 80 worker on the floor.
you are not alone i got to close and reopen my assembly for every part i want to open.
Message 22 of 29
BDCollett
It is a unique problem, and I don't think anyone was able to see why it's happening to some people.
Message 23 of 29
johnsonshiue
Hi! We do have an issue related to this behavior. It has been reported as INVGEN-72927. We are working on a fix. In the meantime, try using Refresh command to see if it helps (File -> Manage -> Refresh).
Many thanks!
Software Test Engineer
Message 24 of 29
iamerm
Thank you @johnsonshiue
In regards to INVGEN-72927, if any other users are reading this thread & would like to report having the same difficulty, what's the best way to do so?
Message 25 of 29
johnsonshiue
Hi! Please feel free to contact Autodesk Product Support and escalate the issue (INVGEN-72927). In this particular case, I think we will have to wait for the fix.
Many thanks!
Message 26 of 29
DperronU8V4S
i have found that i can't have the part open in a .idw at the same time that the .ipt
having a .idw open with the .ipt in it bring the error every time.
Message 27 of 29
iamerm
Thanks for adding to the discussion @DperronU8V4S
Unfortunately we haven't identified a consistent trigger.  For us the the behavior seems to be more random.
Message 28 of 29
johnsonshiue
Hi! The coming updates (2024, 2023, and 2022) should address the issue. Please install it when it becomes available. And, report back the findings.
Many thanks!
Message 29 of 29
iamerm
I see this is addressed in the 2024.2 Update.  From the release notes:
Resolved an issue causing an incorrect message dialog about a file loaded into cache being different than the file on disk to display. INVGEN-72927
I just installed it.  I will try to report back with results.
