Inventor ANSYS Plug In Issues
I'm trying to figure out how to get the ANSYS add-in, into my Inventor 2017 ribbon.
These are the steps I have taken so far:
1) Open ANSYS CAD Configuration Manager
2) Once open, under the CAD Selection tab, select Inventor & sub option, Workbench Associative Interface
3) Navigate to CAD Configuration tab and select, Configure Selected CAD Interfaces
Once I finish step 3, I get:
Prerequisites ..... Configure Success
AI Workbench PlugIn .... Configure Success
Then I go back to Inventor, navigate to the tools tab, and open Add-Ins.
Under the Applications tab I still don't see any option for the ANSYS Plug-In.
I've also verified the files paths in the ANSYS CAD Configuration Manager, under Display Configuration Log File are valid.
Thank you in advance for your help
Lewis.Young
I have a colleague that has ANYSYS installed on his machine, but unfortanetely he isn't in today. For now though you can try the steps outlined in this previous forum post: https://forums.autodesk.com/t5/inventor-forum/ansys-in-inventor/td-p/6742315
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
I accidently solved this problem and now I have ANSYS 19.0 on my Inventor ribbon.
After I ran through the steps from my original post, I decided to continue without the ribbon and load the geometry from inventor into an ANSYS project.
When I opened the mesh editor in ANSYS I got a pop up window saying something along the lines that the ANSYS plug-in has been blocked and if I want to unblock it.
I selected to unblock the plug in.
After this, I went back to the Inventor Add-Ins and loaded ANSYS. It is under "Workbench 19.0".
