RSe Segment Error
RSe Segment Error
thendricks321
Message 1 of 15
RSe Segment Error
thendricks321
I've copied the entire error message it will not open this part any longer. The part was opening fine until the last time i go to open the part and get this message. This is really go to cause a big problem in my assembly which this part file is a part of. I've tried restarting inventor, restarting computer, opening old versions and nothing has worked still get the error message.
Error in reading RSe segment - the number of objects found in the segment does not match the segment summary
Error loading segment PmAppSegment in database O:\SHOP ORDERS\10000-+\12964\CUSTOMER SUPPLIED INFO\1. CAD DATA\08-22-2018 CAD DATA\1\G7515010-6 HINGE COVER OUT 10WAY PWR ASM LH.ipt
kelly.young has embedded your image for clarity.
Replies (14)
Message 2 of 15
Mark.Lancaster
@thendricks321
These types of messages usually point to corruption in the file and most likely you'll not be able to recover it.  If the old version still has the same message its probably an indication to you to re-create the file.
Mark Lancaster
Message 3 of 15
johnsonshiue
Hi! Indeed, this is likely a corruption case. Could you share the part file here? Do you have a backup that can still open?
Many thanks!
Software Test Engineer
Message 4 of 15
thendricks321
Johnson, I've attached the file and no there is no backup or old version that opens.
Message 5 of 15
johnsonshiue
Hi! I have 2019.1.2 update installed. I can open the file without a problem. Have you installed 2019.1.2 update?
Many thanks!
Message 6 of 15
thendricks321
Johnson,
Yes I have it installed. That's weird you can open it everybody that's opened the file besides you has received the same error I'm getting. I sent the file to our Autodesk distributor and they received the same error when opening the file.
Do you think if you sent the file back to me it would work now? Maybe you would need to add something so you can save it.
Message 7 of 15
Can't open here with 2019.1.2, same error as OP.
Message 8 of 15
johnsonshiue
Hi! Try this one for me. I just realize that I have an environment variable turned off to open the file in a debug mode. I have saved the file again and let's see if it opens on your end.
If you know the steps to reproduce the corruption, please let me know.
Many thanks!
Message 9 of 15
Opens now, no problem.
Message 10 of 15
thendricks321
Johnson,
Yes it worked! It this something I can do? If so how do I enter into debug mode?
Message 11 of 15
johnsonshiue
Hi! Unfortunately, the debug mode is for our internal testing purpose. I cannot share it with you. Do you have files in similar situation? Please feel free to send them to me directly (johnson.shiue@autodesk.com). I can take a look and see if they can be opened. If you could find the steps to reproduce the corruption, it would be extremely helpful to finding a fix.
Many thanks!
Message 12 of 15
JBerns
@johnsonshiue,
I found this old post on corrupt Inventor files.
Do you still offer the service to attempt to recover corrupt Inventor files?
We were working on a design today. All was working well until late in the afternoon when Inventor crashed.
Both the original assembly and the backup in the OldVersions folder appear to have become corrupted.
This are the messages received when we attempt to open the assembly:
Thank you for your time and attention. I look forward to your reply.
Kind regards,
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 13 of 15
johnsonshiue
Hi Jerry @JBerns,
Absolutely. I can guarantee you as long as I work for the company, I am always at you and our users' service. But, I cannot promise a fix. Each issue is different and the way to resolve it may not be the same.
Please feel free to send me the files (zip) directly johnson.shiue@autodesk.com. I will take a look and get back to you with my findings.
Have a nice Labor Day weekend!
Many thanks!
Message 14 of 15
dlongGEC3B
So, I just had this error, (5/15/2025) on Inventor Pro 2025.3, on some (empty) placeholder assemblies in a large mechanical assembly.  I was able to close the assembly completely.  Go into vault, change the state of the placeholder assemblies that were throwing this code from released to quick change, I hit checkout assembly in the vault, (but the assembly wouldn't check out) however, after completing these steps I was able to open the empty assemblies from the vault, and then check it in, eliminating the error.
Message 15 of 15
s.bayat
Hey everyone,
I have had this issue this morning. While the assembly and subassemblies have no errors, faults the drawing did not open and niether the old version. It shows the error above. I have opened the totaal assembly and rebuild ervy model state, updated the mass and saved it. Secondly, when you open the drawing to the left of open you have the button Options, click that and open the drawing in defer state. Go through the sheets, and one of the sheets gives a quistion marks, I deleted it and saved it. Then you can close and open again. The drawing is for 90% is saved. If this helps your problem give a thump. Thanks in advance.
