Hole feature - sharing dimension(s) over successive holes?
Can the hole feature be used in such a way that each successive hole shares the same dimension(s) as the first one?
Making multiple holes this way means that I would then only have to change the first hole's dimensions, and all successive holes would be similarly changed.
Thanks 🙂
swalton
I typically use the Pattern command to repeat features.  The nice thing about using a Feature Pattern in a part, is that it can be used as a seed for a Component Pattern in an assembly.  I use the Component Pattern to repeat all the fasteners that fill a bolt pattern.
There are rectangle, circular, and sketch-driven pattern sub-commands for various design needs.
Steve Walton
Inventor 2025
Vault Professional 2025
johnsonshiue
Hi! If I were you, I would define user parameters. Then each Hole simply references those parameters.
Many thanks!
Software Test Engineer
IgorMir
Or just link parameters of the first hole to the follow up ones.
Cheers,
Igor.
Web: www.meqc.com.au
