Inventor Forum
Inventor 2023 not opening 2021 DWG file
11 REPLIES 11
Message 1 of 12
jiri.bures
357 Views, 11 Replies
Hello all,
I have a working Inventor 2021 DWG drawing. Working with the file in 2021 is no problem. I wanted to upgrade to 2023. Model itself is working flawlessly but then when I try to open the DWG Inventor shows me an error message that the database could not be open.
Does anyone have a tip what to do?
I never experienced this when upgrading from older to newer versions.
Thank you.
11 REPLIES 11
Message 2 of 12
BDCollett
in reply to: jiri.bures
Message 3 of 12
jiri.bures
in reply to: BDCollett
Yes, I did, but none of that causes apply to my case. I am opening older version file in a newer version, the file is not corrupt as it works in 2021 normally and it is inventor origin, not Autocad.
Message 4 of 12
johnsonshiue
Hi Jiri,
It looks like a corruption case to me. Please share the files here or send them to me directly johnson.shiue@autodesk.com. I would like to understand it better.
Many thanks!
Software Test Engineer
Message 5 of 12
jiri.bures
in reply to: johnsonshiue
Hello Johnson, I shared the file with you via email.
Thank you for any help.
Message 6 of 12
johnsonshiue
Hi Jiri,
Many thanks for sharing the file! I am able to open it on  2022.3 but not on 2023. Something is wrong for sure. I need to work with the project team to understand the issue better.
Thanks again!
Message 7 of 12
jiri.bures
Ok, Johnson, please let me know if you manage to solve the problem. Thank you.
Jiri
Message 8 of 12
jiri.bures
Hi all,
Johnson confirmed my foundings with being able to open the file in 2021, 2022 but not 2023.
After some investigation he found that opening the DWG file in AutoCAD and running a RECOVER command on it fixes the issue. The file is now fully functional in Inventor 2023.
Message 9 of 12
mdavis22569
Dumb question work around ..
If you open it in 2022.3 save it, can it then open in 2023?   For a temp work around?
Mike Davis
Message 10 of 12
johnsonshiue
in reply to: mdavis22569
Hi Mike and Jiri,
Saving it in Inventor 2022.3 may not help. The corruption is with some AutoCAD dwg objects. Inventor cannot help salvage the data.
Another workaround our project team found is to save the dwg as idw in 2021 or 2022. However, the AutoCAD blocks will be gone as a result, which is also a proof showing the corruption is with the blocks.
Many thanks!
Message 11 of 12
mdavis22569
Not a problem ... thought it might be a simple workaround ..
Mike Davis
Message 12 of 12
mdavis22569
Mike Davis
Technology Administrators
