@Anonymous
thanks for the feedback, I tried the scenario, invoke Sources command, then add source(a file with unit inch), then the Unit shows as mm with "From source document" rule. could reproduce the problem. logged ticket TRUNINV-2305 to track.
and although this happens, the translated source shape size has no problem. when new nest file, choose inch template, then add sources, the shape could show with inch. hope it helps.
Amy Liu (cui.liu@autodesk.com)
Senior Software QA Engineer
