Inventor Forum
Inventor 2022 Measure Tool Issue
6 REPLIES 6
iUser
1584 Views, 6 Replies
iUser
Anyone else notice the copy function in the measuring tool isn't working? Is there a way to fix this or should I post it on the custimization forum?
6 REPLIES 6
johnsonshiue
in reply to: iUser
johnsonshiue
Hi! Please take a look at the following thread. The fix is undergoing the final validation. It should be available in 2022.0.1 soon.
https://forums.autodesk.com/t5/inventor-forum/measure-copy-and-paste/td-p/10226048
Many thanks!
Software Test Engineer
Many thanks!
bradeneuropeArthur
Hi @johnsonshiue ,
Do you have an overview already of what will be changed/fixed within this update 2022.0.1?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Hi @johnsonshiue ,
Arthur Knoors
SBix26
in reply to: bradeneuropeArthur
SBix26
2022.0.1 was released last week.  The release notes are in the Help here.
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 2004
LinkedIn
Sam B
LinkedIn
johnsonshiue
Hi Arthur,
Yes, here you go! https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
Many thanks!
Hi Arthur,
Many thanks!
abacklund5ZAFN
in reply to: iUser
abacklund5ZAFN
Community Visitor
Community Visitor
I HAVE ALSO USED...
HIGHLIGHT THE OBJECT...
RIGHT CLICK...
PROPERTIES...
CLICK ON LENGTH, A CALCULATOR SHOWS UP
CLICK ON THE QUICKCALC
THE LENGHT OF THE OBJECT WILL BE THERE TO COPY **(NO UNITS OF MEASURE INVOLVED)**
I HAVE ALSO USED...
RIGHT CLICK...
PROPERTIES...
SBix26
in reply to: abacklund5ZAFN
SBix26
@abacklund5ZAFN you are showing a tool from AutoCAD.  This is the Inventor forum...
Sam B
Inventor Pro 2022.2 | Windows 10 Home 21H1
LinkedIn
Sam B
LinkedIn
