Inventor Forum
Inventor 2020 saves automatically to DWG instead of IPJ
2 REPLIES 2
rfgeefshuysen
351 Views, 2 Replies
Hey all,
I've encountered a weird problem and I'm honestly confused if this is a glitch or just user error.
I was making some component and after saving it, Inventor crashed 5 minutes after.
It turns out that Inventor crashed because it couldn't work with the DWG.
DWG?! what? I didn't export the drawing, I saved it as an IPJ.
After the crash I went looking for my file and I did notice a DWG, problem is, Acad can't open it.. neither can Inventor.
Labels (1)
2 REPLIES 2
CGBenner
in reply to: rfgeefshuysen
@rfgeefshuysen
Inventor does not save files as .ipj  That is the format of an Inventor Project file.  Inventor saves drawing files as either .idw, or .dwg as defined in your Application options.  It sounds like you are set up to save as .dwg by default... and there must have been something wrong with this particular file.
What version of inventor are you using?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Hi! I suspect this could be a confusion due to hidden file extension. Try this. Go to File Explorer -> View -> Options -> View -> uncheck "Hide file extensions for known file types."
Many thanks!
Software Test Engineer
Technology Administrators
