I am trying to constrain the axis of a bolt hole on one part to a sketch point on another part in an assembly. Using 'Constrain' only allows me to constrain geometries like axes an faces. I can't see where it would allow me to select a point of a visible sketch with which to constrain the bolt hole axis, contrary to the following post on the Autodesk website:
I'm sure I could figure out some convoluted creation of working planes, but if there is actually a way to constrain to the sketch that would be helpful in many projects. For clarity, the axis of the bolt hole is to align with a marked position along a slot in a mounting arm. The only constraining geometry that Inventor sees right now are the center axes of the rounded ends of the extreme ends. However, I need to position the mating bolt hole at intervals that can only be marked with a sketch.
Thanks in advance!
