Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Inventor 2019 Axis-to-Axis Mate Constraint Default To Forced "Opposed" Solution
jletcher
Advisor Advisor
Message 1 of 133
jletcher
I understand you added it from someones idea, but why could you not have left the default selection the old way? This way it does not screw up other peoples workflows?
When on the fly this thing is now a nightmare. I don't understand why it was even needed but now more clicks more wasted time for me and others.
Make it so users can default to old style please, these are things you should be thinking when making changes. I understand you wanted to please someone but don't do it at the expense of others. You can leave it just change default default to old style, I will never have a need for this new way.
This is going to drive me nuts and many users have already called asking if there is a way to default to old.
This should be easy to fix.
kelly.young has edited your subject line for clarity: 2019 New mate constraint nightmare
Replies (132)
Message 61 of 133
Cris-Ideas
@SteveMDennis wrote:
In pure math an axis really has no direction right?  We can argue that but I think that is why he did axis-axis as undirected. What this means is either "direction" is valid.
When you create a legacy axis-axis mate he would simply say if I can, move one of these axis to the other in the smallest move necessary.
Hope that makes sense to clarify what I originally said.
Actually it makes sense but it only adds to the questions.
So even if you made it aligned or opposed in 2019 actual condition for the solver is still undirectional?
But this is out of this topic.
I hope for more detail conversation.
Send you a message.
Cris.
Cris,
https://simply.engineering
Message 62 of 133
SBix26
There has been a lot of conversation regarding the need for other constraints in addition to the axis-axis constraint to fully define the assembly model, get it all locked down.  This supposedly eliminates any benefit to the directional axis-axis constraint.  The benefit is purported to be only for the newbies who don't know any better.
I'd like to propose that designing a hydraulic cylinder is not the only use for this constraint-- there are plenty of design scenarios in which an axis-axis constraint is the only one needed between two components, so that one can slide and rotate relative to the other (a cylindrical joint).  There should not be a requirement that another constraint be present simply to keep this one from flipping.
In addition, while in the middle of designing a complex mechanism, the axis-axis constraint may be all that the designer has available at that stage of the design, and it needs to remain stable while features and components are added and modified.  A good designer may very well leave a component under-constrained while the features to complete the constraint scheme are still being created or modified.  It's not helpful to have the axis suddenly end up going the opposite direction, especially if you're working with a component that is externally symmetric and you can't easily see that it flipped.
I like the tool as it is in 2019.  It matches the way the plane-plane constraint works.  We just need the preview for the plane-plane constraint to show normal vectors through other geometry as the axis-axis does.
Sam B
Inventor Pro 2019.1 | Windows 7 SP1
LinkedIn
Message 63 of 133
jletcher
@SteveMDennis
Thanks for the reply, I hope you don't mind me tearing it apart.
We have had many many customers over the years complaining about the workflow that @CurtisWaguespack pointed out where to get it pointed in the right direction you had to quit the constraint command and rotate the part and reapply the undirected constraint.
  So over the years of getting the complaints you did not teach them the right way to use it?
I believe (having spoken to many customers on this very topic and having been part of the Inventor development team for over 20 years) that the "problem" was that many people believed an axis-axis mate like this was enough and they did not appreciate the fact that it was truly undirected, i.e. we could flip it anytime later if Inventor deemed it necessary as other constraints were added.
Again so you never shown them how to use it right way by adding a second needed constraint?
The Inventor team did a poor job displaying what this constraint actually did and allowed.
I don't think that is up to the team, that would be on the person that educated the new people and the help files not explaining. But not the teams fault unless they did not show them the right way after the complaint or make better help files.
So once the user got the axis-axis in the direction they wanted but if they did NOT put the second constraint on it to really lock it down than they could easily fall into the other more concerning problem which many of our large customers seemed to do... some future update after adding some other constraint would effectively blow up their large assembly by finally deciding it was time to flip that axis-axis mate and everything went to heck in a handbasket and the large assembly they had seemed to explode!
So instead of teaching the right way you decide the best thing to do is screw all the old time Inventor users by adding clicks to their workflow? So all the people that helped you grow you screw, don't sound logical to me.
 But now you think the new options will be the grand fix, not understanding if they don't put that second constraint in the assembly still can explode.
 So again instead of educating the right way you encourage more bad practices? No logic to that if you ask me.
I recognize that you seemed to never run into this and my guess is it is because you had better attention to detail in adding that second constraint to fully lock it down, but again we had many customers that were not as attentive or respective of this need.
It is not a seemed to it is a fact I never had and none of my people that I taught Inventor has. It is a detail I was taught by Autodesk when I worked as their demo guy and teacher of Inventor.
When we originally did this and released our plans in the beta forum we were actually going to REMOVE undirected. We no longer wanted you to be able to leave your system in this unstable situation (which you avoided by your best practices).
This is scary, may I ask what would have happened to legacy data of your users if you did this?
The new options does not make it stable you have false hopes there. The directed shaft can still shoot out into never never land without a 2nd constraint, so the only thing you did here is encourage more bad practices instead of educating. That is not the Autodesk I remember.
Our technical leadership really wanted to steer users away from doing a workflow that could lead to bad downstream behavior, users are not FORCED to put on the other constraints.
I will say the technical leadership failed, all this does is encourage more bad behavior. Now with this they will believe a 2nd constraint is not need at all because it is facing the right way. It should be encourage to fully constrain the assembly.
BTW: once an assembly blows up due to us flipping the constraint sometime later the cause is VERY difficult to find and correct, as you point out it is an underconstrained problem but those are difficult to find and fix.
I disagree with that.  It don't take but a few minutes to find the issue if you were educated in the best practice and not encourage to do it wrong. I was also the tech guy for issues, you all sent everyone to me because it never took me long to find the whys and educate the user.
We are moving as quick as we can towards having dialogs and panel just remember your last used which would address your problem, allowing you to continue to use Undirected if you so desire.
 Last used will be a resource killer and I advice against it but you will not listen to me on that so I will look forward to more problems. It also will not address my issue because once Inventor is closed last used is no longer there, with all the crashes I have been having last used will be a crash. I would advice user options if you change something leave the old default or put in user options to go back to old.
We are also moving towards having a predictive element to this workflow such that when you make your second pick we will default to the closest answer (aligned or opposed) so that at least after this initial constraint creation you get the same result as undirected.
My closest answer is undirected 100% all the time, aligned or opposed does not save time and does nothing. Yes adding this will help those that don't use best practices but me it does nothing.
I understand that this will not make you happy or solve your problem if the second constraint you always add should be in conflict with the choice we made because instead of flipping silently you will get a conflict.
I don't have a conflict I tried the new options found it to be a great pain in the _ _ _ and returned to undirected and will never use the new option again. There was no time savings but cost more time and more clicks. Improvements should not cost more clicks or more time. Thus the reason I made this thread to get undirected default.
This is a new twist to this that I had not considered, I was convinced that the predictive choice would solve all complaints I had heard about this but this thread changes that for me.
I believe I addressed this above.
We clearly did not get this right for you but as someone pointed out here with this type of change we will not make all 300K users happy.
 If you did not upset me that would be a million users by now. I do not sell Inventor anymore when asked for the best software and this happen when you took my classic interface away and forced users your way.
 But if you listen to what I am saying you would have made them all happy including me. As I have been saying you want to keep the worthless options is fine just make the old way (undirected) the default. You gave people what they thought they needed and you did not change the workflow of the 100K old timers.
If I could go back in time I would NEVER have done undirected nor would there be a Mate and Flush for plane-plan constraint, they would also be a Mate with aligned or opposed options (for the plane normals).
I think both were a mistake.
Again there is nothing wrong with undirected axle constraint the error is the users not learning the best practices. I have client that used Inventor for years and still don't know the right way.But he is paying on issue base right now. When he steps up for complete training that will not be the case.
Heck even Autcad users that used it for 40 years still don't use Autocad right.  So trying to make options in Inventor for these people you are going to chase your tail. Teach them the right way not give them more tools to do it wrong.
As for Mate of Flush I don't think you are thinking that one out. I mean if it was from the start Inventor 1 I can see it but trying to change it now I would not advice it. If you want to go into that many changes you may think of starting a whole new software and calling " If I could turn back time"
Again, I just wanted to share the internal story of how we got here and repeat that we are talking about this a lot. I am hopeful that what we come up with will address your concerns but I honestly don't know if making Undirected the default again will be the final decision. It is an option but I don't want to promise you something that might not come true or start another thread by another user saying "You had it right why did you put it back!!!!"
 I thank you for sharing the story. Here is the deal right now is the time to make it the default not a lot of peole loaded 2019 and most are not use to the new options being defaulted so the best thing to do is make the fix now not in 2020 but with a patch. You have more old timers that got Inventor where it is now and those are the people you should care about keeping happy, and you still have the options making others happy.
 As of right now I get about 5 to 10 people a month asking me about Inventor. I explain it was the greatest software I have ever used, stay away from it.
 They look at me funny and ask why, I explain the Autodesk don't care about the user they make change that force you to do it their way or the change the workflows and you are always learning and you lose productivity on every release and it has become a nightmare to upgrade.
 Then they ask what should they use, I direct them to one of your competitors.
So prove to me you do care make this change.
Message 64 of 133
jletcher
@Cris-Ideas
 Thanks for that link but unfortunately that is not a flip case.
Flexibility is not a fully constrained assembly and I would never recommend it be used for anything but hinges.
I have look at that thread and saved the link you have different issues there and is very easy to fix. I have notice it has not been resolved.
 When I get done here with all the replies I will look more into it and gladly help you out with the solution.
Message 65 of 133
Cris-Ideas
Yes please, but also please pay attention to what exactly is given video about, not to get of topic.
And, as for flipping, watch next videos about this simple bot. It presents how constrain solver is not able to flip the bolt.
And much earlier there have been other threads, like "Flexible nightmare"  where there are also very interesting cases related to axial mate.
Cris.
Cris,
Message 66 of 133
Curtis_Waguespack
@SteveMDennis  this is for you Smiley Tongue
43dc0c358991dfc15ae31af61c386144
Message 67 of 133
Cris-Ideas
Just a quick video how to flip axial in flat assembly (no flexibility involved)
Had no time so this is very basic. But may well illustrate situation during assembly building process ( although in real life no one wants to have jacks assembled like this on top level, and flexible jack is much more desired)
Cris.
Cris,
Message 68 of 133
jletcher
 That's not nice Smiley Sad
Message 69 of 133
jletcher
@Cris-Ideas
 You don't have to..
Message 70 of 133
Curtis_Waguespack
Some times nice and funny can live in the same space... sometimes nice just has to stay on the porch while funny goes out and howls at the moon. Smiley Wink
Message 71 of 133
Cris-Ideas
@jletcher wrote:
@Cris-Ideas
 You don't have to..
I do not have to what?
Cris.
Cris,
Message 72 of 133
jletcher
@Cris-Ideas
 The video you posted @67  you mention you did not want to assembly the cylinder ate the top level assembly. I was pointing out with my video "You don't have to".
My cylinder is an assembly in the top level assembly.
Message 73 of 133
Cris-Ideas
But is is fully constrained and you can only use one of them.
How would you use it if you had to have 100 of same type jacks in an assembly, or worst many jacks of the same type in assemblies in different projects?
According to your workflow I would have to have 100 different assemblies for 100 jacks. Otherwise all of them would just move in the same time.
For me this is not a solution. I need it flexible.
Cris
Cris,
Message 74 of 133
jletcher
@Cris-Ideas
So I did without flex like you asked.
We will work on flex in your thread not this one.
I thought you was trying to show the flip everyone keeps claiming happens.
Message 75 of 133
Cris-Ideas
Have you not noticed that the flip is done in assembly with no flex?
Only indirect axial mate.
Cris.
Cris,
Message 76 of 133
jletcher
No I see you had constraint issue, you accepted the error and then unground the beam and then it did what you told it to do.
 So I only seen what you asked it to do no Inventor axle undirected mate error making it flip.
Message 77 of 133
Cris-Ideas
Are yo really not able to understand.
This is just a simple example with shortcuts to show how flip occurs.
This works like that in the real life:
1) you apply axial mate,
2) than you build your assemlby
3) than because of set of many constrains in the assembly axial you applied in the begging flips.
Constrain issues do happen. What user does depends on him. In this case I chosed to apply the constrain because I need this one and I will solve the conflict next editing constrains applied next. I may have had grounded this beam accidental, or only needed that temporarily on some assembly building stage. Now I ee it conflicts so I change that to have my last constrain valid.
It is quite easy to follow concept I suppose.
Cris.
Cris,
Message 78 of 133
jletcher
No I am not able to understand.
 If you make it fail it will fail, I don't make things fail if it fails there are other issues none related with mate undirected constraint.
Some claim the new options stop a flip of a undirected mate, I have never had this happen or seen it happen to a proper constrained assembly.
What you are showing is improper constraints will make it flip.
Thanks for the attempt but I want to see a proper constrained assembly flip.
Message 79 of 133
Cris-Ideas
You know you are making fool of your self?
Cris.
Cris,
Message 80 of 133
jletcher
Come on @Cris-Ideas there is no reason to call me a fool, I don't see the flip in your 30 second video. I see Inventor doing what you told it to do.
 I want to see a correctly constrained assembly do the flip, you did not have that in the video.
I thank you for trying but it is not what I want to see, don't get upset because I don't see it and start insulting.
