So you went to mocking me because I call this a worthless option?
You alone just proved to all the users Autodesk don't care for them, You can take a bow.
But seeing you typed all this out let me slap it around some.
Personally, still think that either option to be default is not perfect solution.
Personally you don't matter, you don't use this software for production and you should listen to those that do. This is the reason Inventor will fail to be the top software you think what you do is the way and if you don't like it take the road. Thanks for proving my point about Autodesk not caring for those that use their software anymore.
This is not something about default option change, but the mind changes instead.
This is everything to do with default option change, You added time to my projects more clicks for nothing.
It is a workflow change not a mind set change, you added clicks and more time and if forgot I now have to take time to fix.
You cost users money doing this.
Oh I guess it is not your money so who cares right?
If axis-axis constrain start with directional way from day 1 as Face-Face constrain did, and then add Undirected in later, what’s your opinion? You may have thought Undirected is useless.
If it was like this from day one that is what I have learned and knew the extra time it took to pick the options and charged my costumers for that time.
Would I have found it useless, that depends.
I always will try the new options to see if they save time and clicks if they do I will use them if I find them to cost time and clicks for no benefit, yes I would say it was useless.
Seems you are missing the big picture. The options don't upset me, you removing my default is. You changed my workflow and cost me time and money.
In theory, Axis-Axis do have two possible direction solutions, which is similar with “Face-Face” constraint like Mate and Flush since faces own its normal direction.
So, let’s start with “Face-Face” constraints - Mate and Flush. As you know, there is no Undirected for Face-Face constraint, is it right? Besides, Mate was selected as default option. Why nobody complains?
Why no complaints, that is simple that is the way you developed the software and we learned it that way. Now after 15 plus years change it and see how many complaints you get.
The same situation for Insert constraint as well, it does not contain Undirected either and Opposed is the default option. Why nobody complains?
“Axis-Axis” constraints - Opposed (=Mate) and Aligned (=Flush) which is the same behaves compared with “Face-Face”. Additionally, Axis direction control was missing in legacy versions. Now we add this important direction factor back to persist the unique result of constraint chain solving.
It was not missing the developers then knew it would be worthless and here we are I am proving it is.
(well after you watch my video on your attempt to fool a users) Stay tune this is just getting fun.
Again it is not the fact you put in worthless options it is the fact you changed 15 years of the same workflow for thousand and thousands of users added clicks for nothing but cost us time and money.
As for why Opposed is selected by default, please take a look at “Face-Face” or Insert constrain which is selected as default even 50-50 percentage chance and Opposed is the one compared with Face-Face mate or Insert.
Please take a look at they have been like that from day one and the workflow for it has been set for 15 plus years. From the start of Inventor you knew you had to pick those options to get the result you want. You knew that cost was need to charge your costumers for the time to click a option.
Please correct me know if above logic is incorrect for you.
I find no logic in mocking a user that can prove you added worthless options and changed 15 plus years of workflows for no benefits.
Below is a case you are asking for which was created from scratch in Inventor 2018 and every part was full constrained, however, if the design changes a little bit, the result is not persistent any more. Please check out the data from enclosed file and the demo video.
Now the fun begins.
I am really please you took the time to make this assembly, shows me you really hate me to the point you made a file that would fail from the start.
Can I ask how long it took you to figure out what you needed to do to make it fail?
I am even more happy you supplied the files so I can look at them.
Now I made a nice video for you please watch.
So what did you think?
Strange I don't have that issue as you did, don't you think?
The only thing you proved here is Autodesk Inventor Software QA Engineers don't know how to use Inventor, could be why you all are destroying the greatest software there was. I also think you should be removed from the Inventor Quality Assurance Team. How can you assure quality if you don't know how to use it?
I would never EVER teach your method of constraints, it was doomed to fail.
All I did was change 1 constraint and added one. I provided the files for you.
This is why these new options are worthless and if someone would teach the person that wanted these options the right way to constrain we would not be here today.
There is no directional bug like @johnsonshiue believes there are just people that need to learn the right way to constrain an animate Inventor files.
Again keep your worthless options just set the undirected as the default. You keep everyone happy why don't you understand that?
This is the time to step up and prove you care for all the users that started with Inventor from day one, if it was not for us, we all would be on Solidwork's forums.
Screencast will be displayed here after you click Post.
2de1904f-c787-47b6-9f37-6735ce7010d2
