Inventor 2019.2 Update Error with Copy Design
ferrisb
Message 1 of 134
ferrisb
This morning I installed update 2019.2 on a Windows 10 workstation.
Now my copy design from Vault does not work.
Can anyone else reproduce this or, possibly know the solution?
For now I just uninstalled that update, and it works as normal.
Replies (133)
Message 101 of 134
andy-axium
Anybody know if installing 2019.3 over 2019.2 works without the need to re-do all the regestry and file copying needed to get Copy Design working in 2019.2?
I have to aggree with gnr10 that I expected the next update to include a fix for the Copy Design problem.
We still have one m/c on 2019.1 as it is such a pain doing the changes manually.
Message 102 of 134
johnsonshiue
Hi! 2019.3 includes every prior updates and new fixes. It should install over 2019.2 or any prior update.
Many thanks!
Software Test Engineer
Message 103 of 134
ChrisMitchell01
You are correct that this 'should" have been fixed but it wasn't in Inventor 2019.3; the real fix most likely needs to come in the form of a patch for vault not just Inventor.
So if you had issues with Copy Design with 2019.2 then the same workarounds will need to be applied with 2019.3 too.
Sorry I don't have better news.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 104 of 134
ferrisb
Thanks Chris.
What I have found most efficient when this issue seemingly randomly occurs is to:
-Close Vault
-Open Inventor Viewer
-Re-Open Vault
Seems to work every time.
It is frustrating to open Vault, browse to what I want to copy, find the issue is active, close Vault & start over, but it is what it is.
Message 105 of 134
kmiller
I really hate to resurrect this post.... but...  I am going too.
I am trying on one system to go from 2019.1 inventor to 2019.3 without installing 2019.2 first.  Reason being is I am just trying to test and gather set steps (that will work) in order to update some of our systems for testing.  I have walked through and done all the steps indicated in our previous posts.  Even the ones I have personally confirmed worked when 2019.2 came out.  But copy design is failing miserably and after trying everything I can't get it to work.   Windows 7, Inventor 2019.3, vault 2019.1.1, I did the adp core.dll fix, reg hack, and copied additional files as well as reboot, run as admin (inventor, vault, and inventor view), etc...  more than once.  This was yesterday.  Was hoping today it would magically fix it!  Wasn't so lucky.  Running Vault Basic.  This nasty message that seems to haunt us has been the one showing up again.
I checked the value of the current version in the registry to make sure it was pointed to 2019 inventor and it was.
The only thing I can think of is on this machine is I did not update to 2019.2, I went from 2019.1 to 2019.3.  The machine I initially tested this work around on I went from 2019.1, to 2019.2 (did the patch fix) then updated to 2019.3.  Do you think that could be my issue?  Is there some other registry setting or something I can check to make sure the system forces to re-register?  I never did get that message and before doing all of this I was working in 2018 for a while.  So it very well could be that, I just don't know how to check any more than checking the current version path stored in the registry and the fact when I open up files through windows explorer it does open up in inventor 2019 (not my normal practice).  Everything I think I could check in terms of re-registering it seems to all be pointing to 2019.  But I could be missing something.  Open to any more ideas.  Thanks.
If this response answers your question please click "Accept as Solution".
Message 106 of 134
kmiller
I am sorry...  it was my mistake.  work around seems to have worked even skipping from 2019.1 to 2019.3.  For some reason it won't let me delete my previous post.  I was testing it on another machine and I think I just copied the 11 files to the wrong location.
Message 107 of 134
t_fransman
opening inventor viewer first also works for me. Annoying but effective.
Message 108 of 134
t_fransman
well now inventor will not open at all ughhhhhhhhhh
Message 109 of 134
johnsonshiue
Hi! I am sorry I am confused. You mean now Inventor fails to open now? Have you installed 2019.3 update? Do you see any error message when you start up Inventor?
Many thanks!
Message 110 of 134
t_fransman
I was able to open it via run as administrator. Working now. Thanks
Message 111 of 134
guido_66
@rachel_li wrote:
Hi all,
Please try below steps which solve the copy design issue in one of the reproduced environment.
  1. Close Vault and Inventor application
  2. Launch InventorView.exe from Inventor\Bin folder as an Administrator
  3. File > Projects > This will show “Register..” dialog.
  4. Choose “yes”
Please let me know if it still doesn't solve your case.
Rachel
After reading 4 pages of possible solutions that did not work, this one was the first that worked for me!
Message 112 of 134
guido_66
Well, that solution only worked once! Tried to do the same todat but no luck this time.....
I hope fixing this has top priority at Autodesk.
Message 113 of 134
Madhan_T
Hi, @guido_66 ,
Could you please try deleting the following files from .\Autodesk Vault Basic 2019\Explorer folder and let us know if that works?
"acio.dll" OR "AcIOLite.dll" OR "xerces-ad-c_3.dll" OR "DwgService.dll" OR "fbp.dll" OR "rse.dll" OR "RxInventorImpl.impl" OR "utx.dll" OR "utxshared.dll" OR "WinSupport.dll" OR "AcIdViewObj.dbx"  OR "adp_core-6_1.dll"
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
Message 114 of 134
guido_66
Yes, this fixes it for me! I've restarted my pc to be certain and after that copy design still works.
Message 115 of 134
Madhan_T
Thank you for the quick update @guido_66
Madhan
Principal Engineer
Autodesk, Inc.
Message 116 of 134
andy-axium
So when was it that 2019.2 messed up copy design?
Really poor from Autodesk that this is still an issue.
Solidworks looks more attractive as each week goes by!
Message 117 of 134
scottmoyse
You're in the minority with that viewpoint.
Scott Moyse
Did your question get successfully answered? Please accept the post as a Solution to help others find it.
CAM Consultant and owner at Nominal Systems. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 118 of 134
Madhan_T
Hi @andy-axium ,
We apologise for the inconvenience. We were unable to reproduce this consistently in our internal systems and hence the delay in finding the root cause. We are working on this with the highest priority to have it resolved.
Please contact our product support in case if you have any further questions. We would be glad to assist you.
Madhan
Principal Engineer
Autodesk, Inc.
Message 119 of 134
krm
Community Visitor
Community Visitor
It did not work until I added this file:
@ChrisMitchell01 wrote:
A few remote sessions were hosted with @eric.roades & these workarounds addressed Copy Design & View in Window not working:
  • Run regedit
  • Create a Registry Key called HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor View
  • Under that, create a String value called Location
  • Set the value of Location to be the path to where the InventorView.exe resides on disk. Eg: Location=C:\Program Files\Autodesk\Inventor 2019\Bin\
 Copy these 11 files from the ...\Autodesk\Inventor 2019\Bin folder to ..\Autodesk\Vault...\Explorer folder :
Please ensure to backup the entire Explorer folder prior to doing the file copy.
  • Launch InventorView.exe as Administrator.
  • Launch Vault Basic 2019 as Administrator.
  • Copy Design should now work.
The following was needed to get "View In Window" to work:
  • Launch Inventor.exe as an Admin which prompted to Choose “Yes” for re-registration, (may be followed by usual subscription login or other licensing messages).
Once the re-registration is completed, View in Window should work.
Could others with this issue please try these workarounds & report back here ?
Chris
Message 120 of 134
kmiller
I have been using these work arounds on multiple computers within our department (windows 7), even a bran new pc just received (windows 10).
Making sure the following is done:
Installing 2019.3 Inventor service pack
Installing 2019.1.1 Vault Client service pack  (we are running vault basic)
Importing registry option (as noted)
Copying 11 files as instructed.  Along with the "adp_core-6_1.dll" file fix (so total of 12 files)
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
You need both of these fixes or it won't work if you are trying to run 2019.2 inventor or higher.
Launch inventor and launch vault.  Test vault to see if copy design window will pop up by initializing the copy design function.  If it shows up generally you are good to go.  once in a while I will have to launch inventor view 2019.  Keep in mind I am an admin on my machine so that might make a difference if you are not.
Hope this helps.
