Inventor Forum
Inventor 2018 (Inventor is not able to detect VBA on your system)
3 REPLIES 3
bradeneuropeArthur
1813 Views, 3 Replies
bradeneuropeArthur
When I start Inventor I receive the following error:
Inventor is not able to detect vba on your system.
How can I solve this
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
3 REPLIES 3
CGBenner
@bradeneuropeArthur
Try this
Hopefully that will do it.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
@bradeneuropeArthur
Try this
Chris Benner
bradeneuropeArthur
@CGBenner
Thanks, but I need the msi file for 2018.
Where can I find that,
Arthur Knoors
@CGBenner
Arthur Knoors
johnsonshiue
Hi Arthur,
You will need to locate the Inventor install media (download/extracted folder). Go to the following folder and find the appropriate msi.
\Setup\3rdParty\x64\VBA
Which msi to use depends on your locale. You need to check https://msdn.microsoft.com/en-us/library/ms912047(v=winembedded.10).aspx to find the proper locale id.
Many thanks!
Software Test Engineer
Hi Arthur,
Many thanks!
