Inventor Forum
Inventor 2018 doesn't show Unresolved Parts
10 REPLIES 10
Message 1 of 11
Fouad-l
573 Views, 10 Replies
Hi all.
I cant see in navigation bar which components needs to be resolved.
In inventor 2017 i was able to see Interrogation icon next to Unresolved components
inventor 2018
inventor 2017
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Tags (1)
10 REPLIES 10
Message 2 of 11
mcgyvr
in reply to: Fouad-l
Working fine here.. I see you can still scroll more.. You sure its not just down further in the list?
Of course your color scheme is also causing big problems there too..  (But I doubt that would effect the icon not showing properly like it is the text)
Message 3 of 11
Fouad-l
in reply to: mcgyvr
Hi. Thanks for the reply.
Yes i can scroll more but there is no icon in all component list, i
captured this part to show that the whole assembly has an unresolved icon.
I hided all component names in order to respect my company privacity. It is
not a theme problem. All names apears correctly.
Message 4 of 11
Fouad-l
... The unresolved part belongs to another subassemblies.
Some of this parts are derived, and others are removed from the project folder.
Message 5 of 11
mcgyvr
Ok so the unresolved part is a component of a subassembly?
Let me try that situation and see if that shows for me..
Message 6 of 11
mcgyvr
in reply to: mcgyvr
Ok... Yes when the unresolved part is a component of a subassembly then there is no icon next to the subassembly like there was in older versions..
This is a "regression/bug" and hopefully they are aware of it..
@Anonymous Johnson are you aware of this regression?
I can confirm it on 2018..
Assembly1 is has an unresolved component
Message 7 of 11
mdavis22569
in reply to: mcgyvr
Do you have the ignore unresolved parts enabled?
It should give you a warning when you're opening this assembly....
What I'd do ......start opening the assemblies in it one by til  you get it
Mike Davis
Message 8 of 11
Fouad-l
in reply to: mdavis22569
Hi @mdavis22569.
No, i don't have the ignore unresolved parts enabled.
In this case i know which assembly/part need to be fixed. It was an older version of a part that was removed from the folder.
I just want to informe Inventor Team about this issue.
Message 9 of 11
johnsonshiue
Hi Latrach,
Many thanks for letting us know the issue! Is this related to the component name missing in the browser issue you reported earlier? Or, this is a separate issue? I will work with the project team to understand this behavior better.
Thanks again!
Software Test Engineer
Message 10 of 11
JarFu
Thanks your reporting! Looks Inventor 2017 & 2018 both have problems on the certain color theme.
Could you let's know your color (Windows Color and Appearance) and/or your Theme settings? I tried High Contrast themes but fail to reproduce the issue.
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
Message 11 of 11
Fouad-l
in reply to: JarFu
Hi.
The problem is not related to component name in itself. I have hided component names ( with paint) to respect company privacity. All parts apears "correctly".
The problem here is no showing Unresolved parts/Components.
Anyway, i have attached my Windows Theme in case it serves to invistigate the issue
Technology Administrators
