Hi all.
I cant see in navigation bar which components needs to be resolved.
In inventor 2017 i was able to see Interrogation icon next to Unresolved components
inventor 2018
inventor 2017
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Working fine here.. I see you can still scroll more.. You sure its not just down further in the list?
Of course your color scheme is also causing big problems there too.. (But I doubt that would effect the icon not showing properly like it is the text)
@Fouad-l wrote:
... The unresolved part belongs to another subassemblies.
Some of this parts are derived, and others are removed from the project folder.
Ok so the unresolved part is a component of a subassembly?
Let me try that situation and see if that shows for me..
Ok... Yes when the unresolved part is a component of a subassembly then there is no icon next to the subassembly like there was in older versions..
This is a "regression/bug" and hopefully they are aware of it..
@Anonymous Johnson are you aware of this regression?
I can confirm it on 2018..
Assembly1 is has an unresolved component
Do you have the ignore unresolved parts enabled?
It should give you a warning when you're opening this assembly....
What I'd do ......start opening the assemblies in it one by til you get it
Hi @mdavis22569.
No, i don't have the ignore unresolved parts enabled.
In this case i know which assembly/part need to be fixed. It was an older version of a part that was removed from the folder.
I just want to informe Inventor Team about this issue.
Hi Latrach,
Many thanks for letting us know the issue! Is this related to the component name missing in the browser issue you reported earlier? Or, this is a separate issue? I will work with the project team to understand this behavior better.
Thanks again!
Thanks your reporting! Looks Inventor 2017 & 2018 both have problems on the certain color theme.
Could you let's know your color (Windows Color and Appearance) and/or your Theme settings? I tried High Contrast themes but fail to reproduce the issue.
Hi.
The problem is not related to component name in itself. I have hided component names ( with paint) to respect company privacity. All parts apears "correctly".
The problem here is no showing Unresolved parts/Components.
Anyway, i have attached my Windows Theme in case it serves to invistigate the issue
