- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've run into what I believe to be a bug in the 3D sketch environment. Create a 3D sketch and place 3 lines on the sketch. Lock down two of lines so that they cannot move at all. Now place a coincident constraint between the third line and the midpoint of each of the first two lines. Now delete one of the midpoints and this is where the bug is. It deletes all of the midpoints when you delete one. Also the third line should show as fully constrained after the coincident constraints are applied (I know the endpoints aren't fully constrained yet, but if you do this same thing on a 2D sketch it shows as fully constrained).
Here is a screencast in case my description is confusing.
kelly.young has edited your subject line for clarity: 3D sketch bug
Andrew In’t Veld
Designer / CAD Administrator
