STEP file IMPORT template
Message 1 of 20
Hi all. I am learning Inventor and so far it goes pretty ok.
I figured out that when I open STEP file (or any other 3D exchange files) Inventor uses Standard.ipt as a template part. So I made my own "Standard.ipt" part and Standard.iam in case STEP file is an assembly. Is it possible to force Inventor to look for other template parts instead of one with name "standard"? Is there a setting that controls this?
Thank you!
Replies (19)
Message 2 of 20
jhackney1972
I do not know of a setting to tell Inventor which template to use when opening a STEP file.  As you said, it will use the Standard.ipt or iam template located in the base template folder.  I would recommend taking your company templates and saving them to this folder replacing the Standard templates using the same names.  I would recommend that you save an archive copy of the Autodesk Inventor templates for possible future use before doing this.  You can have as many folders below this top level templates folder as you wish.  In my attached Screenshot, you will the the top level folder is highlighted showing the Standard templates and a folder labeled "Beyond the Drafting Board" (my Blog name) containing all my special templates. All the Standard templates are actually the same as the "Beyond the Drafting Board" templates only they have been renamed forcing Inventor to use them for common operations.
John Hackney, Retired
Message 3 of 20
johnsonshiue
Hi! If I understood this workflow correctly, most Import workflows do rely on Standard.ipt or Standard.iam as the template file. If they do not exist, Inventor will use internal template files, which users do not have any control over.
Many thanks!
Software Test Engineer
Message 4 of 20
johnsonshiue
Hi! You could consider setting different Project files with different Template path. Each project can point to a different set of Standard templates for importing purposes.
Many thanks!
Message 5 of 20
Thank you all (both of you) for reply.
I knew answer will be "negative" because I have found same questions asked almost 8 years ago. Maybe this will sound as a runt but it just does not make sense that Inventor knows which template part to use when importing non-native part but there is no option for us to point to desired template file. Especially, that only thing is different file name. This also applies for selecting imported part to be imported as part or as assembly. If I bring STEP file into an assembly, I can select that model to be imported as part or as assembly, but when I open same STEP file, that option is disabled. I just wonder why this is the case.
Message 6 of 20
Johnson,
What you suggested will work, because I will set template path for project to different folder so Inventor will look for Standard.ipt in that folder. So what different would it be if that option (pointing to ipt file in folder) was available on "import part window"? Am I right or I am missing something?
Thank you.
Message 7 of 20
johnsonshiue
Hi Danilo,
This is a design choice. Certainly, we could have offer the template selection in Options dialog in Import dialog. However, the user would have to manually select it when needed. It might be cumbersome to do when he has a large number of files to import. The other thing is that assembly and part templates will be offered but some import file types have to be parts only. These variations in behaviors make the UI interaction very complicated. We should have documented the workflows better. I will work with the project team to see what we can do better.
Many thanks!
Message 8 of 20
Johnson, thank you for reply.
Please, take a look at how Creo manages opened non-native files in attached picture. You can select to open STEP model as part or as an assembly and I also can choose which template Creo should follow for imported file. In case STEP file is single part, assembly option is grayed out. But I also have an option to open STEP assembly file as a part. If template check box is not selected, then Creo uses it's default template. With this logic, I can select to open STEP file and then select template that we use for purchased parts, or I can select other template for manufactured parts that is made as purchased but altered part.
This template selection stays current for any new non-native part that Creo opens until we decide to change it or Creo session is closed.
I would not mind Inventor not having this option but since we cannot choose files names for assembly components, when we save an assembly, I end up having a lots of parts that have no meaningful names nor I need them at all since they are part of assembly that I need. And all these files "pollute" my folders. So I end up shrinkwrapping these assemblies and deleting files but this is time consuming.
Message 9 of 20
johnsonshiue
Hi! You got a good point here. Indeed, I think it would be nice to have options in Import dialog allowing users to specify what template file to use. Do you mind submitting an idea to Ideas forum if it does not exist yet. In the meantime, I will work with the project team to see what we can do.
Thanks again!
Message 10 of 20
Thank you Johnson. I will do it.
Message 11 of 20
SBix26
You can import an assembly to a single part-- start a new part file (whatever template you wish), then use the Import tool to bring in the STEP assembly.  This gives you the same dialog as always, allowing you to select which parts will be included (as bodies instead of separate parts).
If you create an idea for this, please post the link in this thread so we can easily find it to add our votes.
Sam B
Inventor Professional 2018.2
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Message 12 of 20
Cadmanto
That is why I created this idea some years ago.  This is an age long issue that has not been implemented yet.
This idea needs more support.
https://forums.autodesk.com/t5/inventor-ideas/ability-to-select-which-template-to-use-when-importing...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 13 of 20
dusan.naus.trz
a customer called me now and found this topic. Cadmanto created the ideas in 2013. What's going on? I liked the picture for conversion with Creo. Picture made by danilo.veljkovic Template selection - Creo.png. Why is it no longer in Inventor? How many votes do you need to make the realization?
Message 14 of 20
SBix26
It's also still true that you can start a new part or assembly from any template you wish, then use the Import tool to open the STEP file into that new file.  Not quite as intuitive as choosing the template from the File Open dialog box, but certainly no more difficult.
Sam B
Inventor Pro 2021.0.1 | Windows 10 Home 1903
LinkedIn
Message 15 of 20
dusan.naus.trz
Hi, I only send for demonstration to others. I understand the transfer.
what you write is only for one file. Not for multiple parts or multiple assemblies in an assembly. All this, as Step.
The procedure I present is for all files.
Video in the attachment.
Another idea. Just for overview.
I understand that programming is not easy. This example is not so terrible, but it can be improved.
I try different programs. Solidworks, Creo, SolidEdge, NX, Catia
I claim Inventor is 10 years behind these programs. Most in pattern and mirror functionality. This is not good for sales.
You are dedicated to Fusion 360 and none of the programs is perfect.
Inventor has many programs in the package unnecessarily. Fusion 360 is cheap and nice for simple things. Inventor has been neglected for a long time.
We'll see what time shows in the future and what programmers create.
What is in color in Excel are the most important things for the future.
Message 16 of 20
johnsonshiue
Hi! I don't think the particular idea has been implemented. Nor do I hear it on the near-term radar. Please feel free to discuss it further on Inventor Feedback Community.
Many thanks!
Message 17 of 20
andreas.jonssonF98YC
Hi I see that nothing have happened with this issue in 2024 release either. We investigate how we will work with templates that have no code and triggers and one that has. for example we have big projects where we use both code and not so this issue makes it more complicated for us because we would thereby not have a standard.ipt and then you have one internal template that does not we as users can change? Why did you not use the standard default template in C:\Users\Public\Documents\Autodesk\Inventor 2024\Templates if we not are able to choose which template we would like to use for stp import in the menu.
Why is it complicated to have this option? haven't you already solved it for new part in assembly? I think it is a bad idea to have standard.ipt hardcoded as well because like I said we would like the user to select template that shall be used so we are able to work with both code and not. We have so many issues that I comment on that seams to be more than 5-10 years old and nothing have happened. how are we suppose to make a good workflow with codes and optimazation if there are so many things that prevents it and do not been solved in those years.
Message 18 of 20
hugo.trepanier
I've many customers that using Inventor template with Ilogic rules based on Forms with Text Parameters, rules etc for their production info. It could be very productive to have this template for all imported files like step. This is hard to understand why it's not possible in the latest version...
Hugo Trepanier
Autodesk MSD Application Specialist
Message 19 of 20
if you name the customer template as standard.ipt then it chooses this template with forms and rules etc.
But the problem is that when you have for example one template with code and scripts in it and one that shall not include any rules for the same customer you could not choose the one you like to do the stp import on and for the third autodesk have implemented a hard coded standard template that nobody can modify if you do not have named one of your template files as standard.ipt which is so wrong. the best way would have been to just give the user the right to choose their own name on the templates for example Customername_No_Code.ipt and Customername_with_Code.ipt and then be able to choose which template to have in stp import.
Message 20 of 20
richardZEVN7
Observer
Observer
The to overcome this and still maintain all your existing templates....is to open the desired template as if you are making a new part.  Then use the import option to import your non native file.  This also maintains all your custom parameters and iLogic.
