Message 1 of 9
When trying to create a work feature in 2018.2 the automatic select other does not work. You can still right click and use select other, but the drop down will not pop up on its own. It works fine with other features like the hole command, but not with planes, axis, or points. It happens in both part and assembly environments.
kelly.young has edited your subject line for clarity: Select other bug
Andrew In’t Veld
Designer / CAD Administrator![]()
