Inventor Forum
Inventor 2018 Add-Ins ribbon disappears since adding iPropWiz 6
2 REPLIES 2
618 Views, 2 Replies
I recently upgraded from Inventor 2016 to 2018. I reinstalled iPropWiz 6 (which I had working on 2016, no problems) and it sort-of worked for the first instance. The window appeared, but wasn't big enough and I couldn't resize it. I tried restarting Inventor, but this killed it.
Since then I've always had the same thing: Add-Ins ribbion completely blank. I tried repairing the iPropWiz install, to no avail. I've attached a screenshot of what it looks like now. I have no idea how to fix it.
2 REPLIES 2
MSD_takaseh
Hello jason.adamson,
iPropWiz6 seems to be unsupported in Inventor 2018 unfortunately according to the APP Store.
It would be better that you would ask to "sales@c3mcad.com" but please try followings just in case.
*Right click on the ribbon > Reset Ribbon
*Tools > Add-Ins > iPropWiz > Loaded/Unloaded and Load Automatically
*Right click on the ribbon > Show Panel > iPropWiz
Thanks.
Hitoshi Takase
Ah ha!
Re-installed iPropWiz. It's in my Add-In Manager again (Tools>Add-Ins). Needed to set "Load Automatically" again, so now I've got it coming back up.
Still can't resize the window. But what I can do is dock it in the window, then make it wider. To dock it you need to grab the light-grey tab, not the dark grey bar at the top, then move it to the side of the window. Widening the window reveals the properties editor.
Seems odd I can't resize the window, or drag it by the dark-grey bit...
