Inventor 2017 Constrain Spring Positioned On Axis To Rotate With Fixed End
Message 1 of 23
Hi, I would like you to help me with a problem that I have when doing the constrain
I would like to know how to do so that a spring that is positioned on an axis can rotate one of the legs and the other is fixed
Thanks for your help
kelly.young has embedded your image and edited your subject line for clarity: PROBLEM CONSTRAIN
Replies (22)
Message 2 of 23
j.palmeL29YX
I'd suggest to model 2 different springs (one with legs in the start position and on with legs in the rotated end position) and then use view representations.
Or dou you want to animate the rotation of the one leg?  That's possible too, but I wouldn't do that. It's not worth the trouble.
cadder
Jürgen Palme
Message 3 of 23
johnsonshiue
Hi! Please share the files here. There is a technique involving creating surface and using Transitional constraint. Another way is to do it in Dynamic Simulation environment.
Many thanks!
Software Test Engineer
Message 4 of 23
Hi, I attach the file
kelly.young has zipped your files for clarity.
Message 5 of 23
johnsonshiue
Hi! The file you attached is incomplete. I also need "Torsion Spring" subassembly and its components.
Many thanks!
Message 6 of 23
Hi, I resend the attachment
Thanks.
Message 7 of 23
johnsonshiue
Hi! Many thanks for sharing the files! I get what you are trying to do now. You want to simulate the torsion spring at various stages of load, right? For this particular model, I don't think there is a way to do it in Inventor unfortunately.
In order to create such movement and deformation, the spring sweep path has to be extended or contracted. 3D Helical path only allows change in parameters associated with the path, not by the movement within the assembly. There might be a way to do that by using iLogic rule but the relationship would be brittle and easy to break.
I have to say I do not see a reliable workflow to simulate the movement. I am sorry.
Thanks again!
Message 8 of 23
Cris-Ideas
What is the angle you want this to rotate?
Cris.
Cris,
https://simply.engineering
Message 9 of 23
j.palmeL29YX
Unfortunately I still don't know if you want to animate the movement or if different static positions are sufficient.
If you don't need an animation, here attached a basic idea how to solve the issue.
A screencast how to manage it: https://knowledge.autodesk.com/community/screencast/160b8108-ecc4-4a91-895b-3d74242599ec
The Inventor files come from Inventor 2015. (I can't open your files, therefore I modelled myself it with fictional dimensions)
Jürgen Palme
Message 10 of 23
Cris-Ideas
Would this suite you?
It mimics what you are after
Cris.
Cris,
Message 11 of 23
Sorry if was not clear enough in reality the moving leg of spring rest on the Part and when the part rotate the leg also while the other leg of the spring should remain fixed
Message 12 of 23
Hi, That would be the idea look at the reference images
Message 13 of 23
I share the file
Message 14 of 23
Cris-Ideas
I tried to put hits whole together but for now there still are problems witch constrains that do not work so well.
Will need to do more work on that to find a stable reliable way.
Cris.
Cris,
Message 15 of 23
Hi, I really need the animation of the movement but if it can not be done
I will have to do it the way you proposed
Message 16 of 23
Cris-Ideas
It can be done,
It is only a matter how complicated it is going to be.
I hoped easy way would do fast, but unfortunately run on to basic problems.
When do you need that?
Cris.
Cris,
Message 17 of 23
Cris-Ideas
In the end I have made something like this:
AI 2019 data set for download :https://autode.sk/2p0nCY6
Cris.
Cris,
Message 18 of 23
Hi, I can not open the file
with what inventor's version is made ?
Message 19 of 23
Cris-Ideas
AI 2019 unfortunately.
Have you seen the video? For some reason youtube stopped working.
in case here is a link to download video: https://autode.sk/2QnC6hr
Cris.
Cris,
Message 20 of 23
Hi Crhis,
I wanted to thank you for your help
best regards
