Inventor 2013 was working just fine until I installed SP1.1 X64. Now it just locks up the second I try to access the application options.
Solved by SBix26. Go to Solution.
Hello Rhjones,
From system, there is only one CER submited at 10/31/2012, which is afte Inventor 2013 Sp1.1 launched. This CER does not contact with any defect, it sounds a random one as you described.
Does Inventor crash in later time? Could you repeat the steps?
I'm getting the same problem. Inventor works just fine until I click on Applications Options. Then everything freezes. I am using a HP laptop.
Any suggestions on what's causing this.
2013-02-15
SAME PROBLEM
This used to work, can not remember the last time.
BUT SYSTEM NOW FREEZES WHEN HITTING APPLICATION OPTIONS
NEED TO CLOSE PROGRAM USING SYS MAN TO REOPEN
XPS 1710 DELL LAPTOP - WIN 7 ULTI
HELP
STILL NOT WORKING
CONTROL PANEL
ADD REMOVE
INVENTOR 2013
REPAIR
FIXED
REBOOT
STILL NO GOOD
RUN **** AMINISTRATOR
STILL NO GOOD
As LarrenSmoot said, normally this crash issue happens at the a specail use account, try to log in software as local computer's administrator to check issue still exist or not. If issue disappared, please check the special user account profile, otherwise, could you submit the CER to analysis this issue? We could not reproduce it at our site.
OK - IT WILL WORK IF I LOG IN AS ANOTHER ADMIN USER ???
WHATS UP??
WHAT DO I NEED TO RESET, CHANGE, LOOK AT ???
HELP
Could you submit the CER to us?
When you met crash, there is a dialog box ask you submit the crash to Autodesk, then input your email and the steps what you have done, then submit.
The system will not crash - INV will just lockup
It has been locked up for 10 minutes while i am sending this
The only way to close is through Task Manager - rt clk - end task
NOTHING IN INV WILL WORK AFTER HITTING APPLICATION OPTIONS
Suggestions ????
Another note - I have to continually reset password to log onlo this form
what a pain
NO WINDOW POPS UP - I KNOW THE WINDOW YOU ARE REFERING TO
THIS IS NOT THE CASE
HELP
Anyway out / without creating another account ????
Also - Who R U ???
RU autodesk ???
Sounds to me as if something is corrupt in your user profile. If you are comfortable editing the registry (standard disclaimers apply here), try deleting the following key: HKEY_CURRENT_USER\Software\Autodesk\Inventor. This is where most of (all?) the Application Options are stored. In addition, in your Windows User folder, try deleting everything Inventor-related, or even everything Autodesk-related. The next time you run Inventor, it will be like a new install as far as your settings are concerned.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Hi
Have the same problem the application manager and the tube and pipe manager makes the program lock but will open when hitting esc. This happens only when i am at home, at the office its al good.
This worked for 2014 as well -
"If you are comfortable editing the registry (standard disclaimers apply here), try deleting the following key: HKEY_CURRENT_USER\Software\Autodesk\Inventor. This is where most of (all?) the Application Options are stored."
