Inventor 2013 Crashes when trying to access application options
rhjones74
rhjones74
Inventor 2013 was working just fine until I installed SP1.1 X64.  Now it just locks up the second I try to access the application options.
Replies (18)
Yong.Jing
Autodesk Support
Autodesk Support
Hello Rhjones,
From system, there is only one CER submited at 10/31/2012, which is afte Inventor 2013 Sp1.1 launched. This CER does not contact with any defect, it sounds a random one as you described.
Does Inventor crash in later time? Could you repeat the steps?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
I'm getting the same problem.  Inventor works just fine until I click on Applications Options.  Then everything freezes.  I am using a HP laptop.
Any suggestions on what's causing this.
SAME PROBLEM
This used to work, can not remember the last time.
BUT SYSTEM NOW FREEZES WHEN HITTING APPLICATION OPTIONS
NEED TO CLOSE PROGRAM USING SYS MAN TO REOPEN
XPS 1710 DELL LAPTOP - WIN 7 ULTI
HELP
Hi Larren, Thank you for contacting Autodesk Product Support. First list see if it Inventor related to do so please log out and ask your IT group for the local Administrator log in. We are aware that most users have some form of administrator right but this can be different from the local administrator account. This helps point us to which direction is best to address your issue. Note: the local administrator for Windows Vista and 7 needs to be activated first before they can be used. This default account helps point us in a direction to best help address your issue. Once logged in as the local administrator of the system launch Inventor and select the application option to see if Inventor locks up. If it doesn't it points to either a permission issue or your Windows User profile is corrupt. To narrow it down further have a user with similar permission as you're that has never logged on to your system. Log in and launch Inventor and select the application options. If that user can launch the application option it the Windows User profile and it will need to be deleted and recreated (your IT group can assist you with that). If when logged on as local Administrator you can repeat the same issue when launching the application options please do a repair as the first step. To do a repair you will need to go to your Start menu select the Setting option and select Control Panel. In the Control Panel Dialog box you will select Add\Remove Programs (for XP) or Program and features (for Vista & Windows 7). In the Add\Remove Programs or Program features dialog box find and highlight your Autodesk Product. With your Autodesk Product highlighted select the Change button. This will launch the Installation Wizard, there you can select the Repair button. Please Note: You may need to have your Inventor DVD on hand depending if components need to be re-copied Give this a try and let us know the outcome of each. Regards, Charlie Mercer Product Support Specialist Manchester, NH, USA
STILL NOT WORKING
CONTROL PANEL
ADD REMOVE
INVENTOR 2013
REPAIR
FIXED
REBOOT
STILL NO GOOD
RUN **** AMINISTRATOR
STILL NO GOOD
Yong.Jing
Autodesk Support
Autodesk Support
As LarrenSmoot said, normally this crash issue happens at the a specail use account, try to log in software as local computer's administrator to check issue still exist or not. If  issue disappared, please check the special user account profile, otherwise, could you submit the CER to analysis this issue? We could not reproduce it at our site.
Yong Jing
OK - IT WILL WORK IF I LOG IN AS ANOTHER ADMIN USER ???
WHATS UP??
WHAT DO I NEED TO RESET, CHANGE, LOOK AT  ???
HELP
Yong.Jing
Autodesk Support
Autodesk Support
Could you submit the CER to us?
Yong Jing
OK - HOW DO I DO THAT ???
WHERE IS IT LOCATED ??
THANKS
Yong.Jing
Autodesk Support
Autodesk Support
When you met crash, there is a dialog box ask you submit the crash to Autodesk, then input your email and the steps what you have done, then submit.
Yong Jing
The system will not crash - INV will just lockup
It has been locked up for 10 minutes while i am sending this
The only way to close is through Task Manager - rt clk - end task
NOTHING IN INV WILL WORK AFTER HITTING APPLICATION OPTIONS
Suggestions ????
Another note - I have to continually reset password to log onlo this form
what a pain
NO WINDOW POPS UP  - I KNOW THE WINDOW YOU ARE REFERING TO
THIS IS NOT THE CASE
HELP
Anyway out / without creating another account ????
Also - Who R U ???
RU autodesk ???
SBix26
Sounds to me as if something is corrupt in your user profile.  If you are comfortable editing the registry (standard disclaimers apply here), try deleting the following key: HKEY_CURRENT_USER\Software\Autodesk\Inventor.  This is where most of (all?) the Application Options are stored.  In addition, in your Windows User folder, try deleting everything  Inventor-related, or even everything Autodesk-related.  The next time you run Inventor, it will be like a new install as far as your settings are concerned.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
rhjones74
Same here.  I just installed Update 2 of SP 1.1.  No help there.  This is getting frustrating!
rhjones74
Yes.  Anytime I try to access my application options.  From the big "I" to the Tools tab.
Hi
Have the same problem the application manager and the tube and pipe manager makes the program lock but will open when hitting esc. This happens only when i am at home, at the office its al good.
This worked for 2014 as well -
"If you are comfortable editing the registry (standard disclaimers apply here), try deleting the following key: HKEY_CURRENT_USER\Software\Autodesk\Inventor.  This is where most of (all?) the Application Options are stored."
Have you found a solution to this issue?
