Inventor 100% CPU crash
Yosssseba
Yosssseba
inventor cpu at 100% and 7000mb of memory while using some futures. what do I need to upgrade on my work station to solve the problem?
CGBenner
@Yosssseba
Hello & Welcome to the forum!
Can you share some more information, please?  What version of Inventor are you using, what features are causing the crashes, and what are your current computer and system specs?  Thank you.  🙂
Chris Benner
Yosssseba
ciao sto usando Inventor 2020, e mi capita che il programma diventi lento e pesante, e che non riponda più ai comandi quando cerco di salvare solo dopo aver usato la funzione "decalcomania" che serve per imprimere un immagine JPEG o PNG in una lamiera. se l'immagine è grande, anche se il file è di pochi kb diventa molto lento, ho controllato il task manager mentre stava accadendo l'ultima volta e segnava Inventor che usava il 100% della CPU e 7000mb di memoria come nella foto allegata.
Questo succede con il PC a lavoro, è un HP Z240 Tower Workstation che ha un processore Intel Core i7-7700 CPU 3,60GHz, con 24GB di RAM.
[Translated with Google 6/5/24 by CGBenner]
Hi, I'm using Inventor 2020, and it happens that the program becomes slow and heavy, and that it no longer responds to commands when I try to save only after using the "decal" function which is used to imprint a JPEG or PNG image on a sheet of metal. if the image is large, even if the file is a few kb it becomes very slow, I checked the task manager while this was happening last time and it marked Inventor using 100% CPU and 7000mb of memory as in the attached photo.
This happens with the PC at work, it is an HP Z240 Tower Workstation which has an Intel Core i7-7700 CPU 3.60GHz processor, with 24GB of RAM.
johnsonshiue
Hi! It seems that you have 24GB RAM. That should be adequate. How much graphics RAM do you have? Is this on a physical machine or a virtual machine? What was the operation before the CPU hit 100%?
Many thanks!
Software Test Engineer
CGBenner
@Yosssseba Hello, do you still need help with this question?
Chris Benner
Logos_Atum
I´d partly blame the CPU´s single core performance. It surely is the last high end intel CPU that was a four core (in 2017), but it didn´t exactly age well. I´d also need more background on the dataset. Also, I agree, that the mem usage is something you can safely forget about in a pc sporting 24 GB of ram.
How many parts are we talking in this assembly?
EDIT:
listed below is just the difference in Single Core Cinebench R15 tasks. And as not everything is about rendering, the difference is much bigger in any regard and all over the board. I gathered this from Igor´s Lab.
You can also compare INVMARK results for your CPU with a recent system.
That´s the closest I found, the slightly faster K version of your CPU.
And that´s the first place
Even if the GPU in the first up and runner is overkill, setups with a 3050 only score a little less.
Dogs aren´t flammable.
