There used to be Inventor Publisher that might have gotten closer to what you may want.. But it was retired due to low usage..
The Inventor Presentation Environment is not a suitable replacement for it and doesn't do what I think you want..
I haven't seen anything from Autodesk or its competition really that would be used by the floor/assembly personnel that guides them through the assembly process..
(Electronic Work Instruction Software I believe its commonly called..)
We created our own solution using a website content management system called Joomla.. Each step is an "article" and you can easily step through the process using next/previous buttons and can create whatever instructions/images/videos you want on each article page..
I've gotten numerous compliments on it from people that I've shown it too..
And you can do it all with little/no programming experience..
We went a step further and did some fairly simply php programming to tie it into our ERP system to pull up real time pick lists/labor recording,etc...
I haven't figured out a good way though to include 3d files that can be rotated,etc... by the assembly staff yet.. But I really haven't looked into it much yet as static images of the 3d model has been more than sufficient..
A quick search found this first..
http://www.assemblyxsoftware.com/
I haven't used it so I can't comment on it but there are other software packages just like it..
