How to Create twisted Extrusion?
Hello there,
I want to create a "twisted" extrusion. I'm having trouble in explaining what I mean exactly with that so please see the attachments.
I have both files aviable but the first one is imported from a .stp format so I cant access the properties. I tried creating twisted planes, project a 3D Sketch with include geometry but I'm not able to make it work.
Any help would be much appreciated. I have no idea how to do that.
S_May
Hi @Anonymous,
please upload the ipt file!
Thanks, here you go.
admaiora
Hi Jake,
can this work for you?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Looks really nice, it also works somehow.
But when I have a slightly different form the spline lines don't exactly match the model (top view.png). In this case the tangend constraint doesn't work that well I think.
I tried using different constraints but I'm not able to make it work.
How can I set the splines to match the model?
Please see the attachments for further info
TheCADWhisperer
Can you attach the original STEP file here?
IgorMir
Hi Jake,
Can you use sheet metal module to get it done? Please see the attached.
Cheers,
Igor.
@Anonymous wrote:
Hello there,
Web: www.meqc.com.au
