Inventor Forum
Infer Constraints in sketch on/off has no change
2 REPLIES 2
kbowen
280 Views, 2 Replies
I had turned off infer constraints in sketches and now that I've turned it back on infer constraints is not working.
Since turning infer back on, I have: restarted inventor, restarted computer, updated the software, turned infer off again and on again.  I have even changed the settings in the Constraint Interference Scope dialog box.  The only thing I haven't tried (that I can think of) is to reinstall the software.
Has anyone else experienced this and how did you fix it.
Thanks for your help!
Karen
2 REPLIES 2
johnsonshiue
in reply to: kbowen
Hi Karen,
Please check if Constraint Persistence option is on. If it is not on, the inferred constraint will not be created. If possible, please share a video showing the behavior you are seeing.
Many thanks!
Software Test Engineer
kbowen
in reply to: johnsonshiue
Thank you @johnsonshiue!
Persist Constraints was the small detail I was missing.  I had read about them (see copied text from "help") however the text below doesn't match the behavior I was desiring.
  • Infer Constraints. When selected, constraints are inferred to the geometry created with the active command.
  • Persist Constraints. Available only if Infer Constraints is selected. When Persist Constraints is selected, constraints are created automatically after you finish a sketch. If Infer Constraints is selected and Persist Constraint is deselected, constraints are not created automatically after finishing a sketch but the Inference position is correct.
